Jannis1
Jul 4, 2023 10:37 AM UTC
Variables do not update in design
I am working with a colleague and some local variables simply do not update in the design when she is entering new values in the local variables window. Some do, some don’t.
I on the other hand are able to update all variables with no issue.
Both are using latest Figma Version via App. Only difference she is working on Windows, I am on Mac.
Celine_Solution
Jul 17, 2023 8:27 AM UTC
Hi @Weston_Ballard ,
For visibility, I can see in the back end that the issue was related due to a missing font for your case. If you see a yellow A? icon:
Manage missing fonts, Manage conflicting fonts and Access local fonts on your computer might all be helpful in clearing those missing font warnings so that changes they make to the variables are reflected in the file’s text.
Still, I recommend you to reach out to the support team to have a deeper look at your file, as it may be another issue. Please contact the team by filling this form: here
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com as an Editor so they can take a closer look. Thank you!
peter.vanbest
Sep 9, 2024 9:14 AM UTC
That’s not the solution; the issue lies in what Vasiliy wrote:
Adam_Fenyvesi
Sep 13, 2024 10:14 AM UTC
Hi all! The issue is indeed hat Vasiliy wrote , but Castillo’s solution works.
So in the assets panel in given design file you have to manually push the update so it refreshes in the components using that variable u changed.
If I’m not mistaken u still have to do this file by file but at least u dont have to manually adjust each and every element.
Eldin_Pindzo
Oct 10, 2024 12:40 PM UTC
I’m still experiencing this issue. Any update?
CamilaB
Oct 10, 2024 2:31 PM UTC
I’m also having this issue with several files that use a specific library. It doesn’t help to update all pages, there’s this variable (that I don’t know which one is) that always says there’s an update but never updates. 🙄
Cindy_Wong1
Oct 24, 2024 1:21 AM UTC
I am also having this exact issue - I updated a color variable in my library file and published it, but not seeing these color changes on components that use that color variable. Both components IN the library file or local files that use that library remain the original color that was used for the variable… Making it very difficult to use variables.
To any other designers who read this, my workaround solve for this at the moment is to delete the old color variable, create a new color variable (with the new hex value), and reassign the new variable to any elements that used the old variable. Then publish your library. Local files should update accordingly.
Figma, please fix this!
Nov 14, 2024 11:50 AM UTC
Hey everyone, sorry to hear you are having issues with variables, and thank you for flagging this! We are not able to reproduce the issue on our end.
Thank you @Deejay_Castillo1 for sharing this workaround to the community. As mentioned, please make sure to accept library updates.
About @Pugovkin_Vasiliy’s case, I see in his support ticket that he marked his issue is solved by checking this article: Review and accept library updates.
Pugovkin_Vasiliy, feel free to continue the conversation via your support ticket if you have any ‘new’ issues relating to this. Your case will be automatically re-opened.
I’ve checked in our backend, we have another similar issue reported by a user that’s been resolved. For that case it appears that the user or another user deleted the mode collection and created a new one. Since these are two different variables, one from one mode collection and another from another mode collection, please also make sure to reattach your variables accordingly.
For others in the community who may encounter a similar issue, we would like our team to investigate it further as the root cause of your issue may be different. Please reach out directly to the support team by submitting a bug report: here
Be sure to use your Figma account email, explain the steps you have done (this will help us to replicate on our end), and include a link to the file and share it with support-share@figma.com as an Editor, so we can take a closer look. Thank you 🙏
Pugovkin_Vasiliy
Dec 17, 2024 4:09 AM UTC
Hey, thank you for keeping in touch with us. So, I learned how to work with this issue, but it looks like a problem to me still in chained library cases.
Typical example:
  1. There is Library A where I store color variables.
  2. There is also Library B where I store components.
  3. Component X in Library B uses Color Y from Library A.
  4. There’s a Design File using Component X. Initially it looks and works as expected.
…from here problems start…
  1. I change the hex value of Color Y in Library A and publish it.
  2. In Library B the update indication comes up, I receive all updates and see the new color on the Component X. 👍
…here I often don’t notice the indication to publish the library changes in Library B, because I didn’t do any changes, I only received the update…
  1. I look at the Design File: there’s no library update indication (though both libraries are included in every file team-wide) and Component X’s color is outdated.
  2. It’s still clear that Color Y is used but the color is old on the element and on the properties panel. Though, as it is linked to the Library A, if I click into color selection and find Color Y in the library- there’s the updated color. 🤯 Screenshot:
To designers stumbling over this: what you need to do is to actually publish Component X from Library B too. This not really obvious, I agree, but it looks logical in one way, though it creates such confusing situations as in step 8.
I suggest library variable linking to be sort of passed-through. So that there’s no need to publish intermediate libraries. You still can (and in some cases need to) publish Library B, but for files having access to both variable and component libraries receiving update from variables should be sufficient if that was the only thing that was updated.
P.S. While writing this it seemed that once I actually received an update at step 7. So, maybe there’s also some buggy randomness factoring in.
Pugovkin_Vasiliy
Dec 17, 2024 4:51 AM UTC
And to further illustrate how confusing it becomes at times… Here all the same steps, but now I have a simple shape in the design file using the same color variable directly from the library. In this case there’s a pending update indication, but things get even worse after accepting the update.
hcarn
Apr 30, 2025 10:43 AM UTC
Does anyone have a fix to this problem? I’ve set up a big design system, the variables have updated just fine for many days, but now the variables in light- and dark mode doesn’t affect the design until I create a new instance or duplicate the component.
The changes done to the “default” color mode gets applied straight away, but other than that I have the exact same problem as Visaliy.
Luis_Rodrigues
May 14, 2025 9:03 AM UTC
Hello. I’m having the same problem here; with nested components, it makes a non-logical reset without a pattern, and variants go back to default in some cases. Predefined icons also reset, even with size variants. When I go and check the instance of a component, the nested variants are set in the correct way, but the instance shows other random variants. I don’t know if it is a coincidence, but it got worse after the update with the new releases of the Config Figma event. I´m working on a huge Design System so deleting modes is not a solution.
