Unexpected behavior for resolvedVariableModes
  • October 11, 2024
  • 46 views
Lorenz_Wohr
resolvedVariableModes is empty if the node doesn’t have at least one variable defined. This is also the case if the parent node has an explicit mode.
Expected behavior: According to the documentation, nodes have default mode values, which should be returned regardless whether the node has a variable or not. resolvedVariableModes | Plugin API
aleksanderd
I am having this exact issue as well. Seems like it’s not possible to do this logic myself either since I can’t seem to find any part of a node that just says whether or not a variable mode is attached.
