Mickey3
Oct 8, 2024 3:35 AM UTC
Text layer preview bug in dev mode
Sometimes, when I select the text layer in dev mode, the preview does not appear. The attached screen is the screen when the same text layer is selected. Sometimes, the preview doesn’t appear like the one on the left. In that case, if you select a different layer and then select the previous text layer again, the preview will appear fine. Is it because I did something wrong? Or is it just a bug?
Oct 8, 2024 7:10 AM UTC
Hi there,
Thanks for reaching out. I’m checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
Toku
Oct 9, 2024 1:27 AM UTC
Hi there,
This was flagged as a bug and our engineering team is working on a fix. We will let you know once this was solved!
Toku
Oct 9, 2024 2:04 PM UTC
Hi there,
It looks like the issue has been fixed! Could you try again after reloading the tab? I just tested it, and everything seems to be working properly now.
Toku
