Brian_Olson
Jan 16, 2025 6:59 PM UTC
Stop adding rects to SVGs that don't exist in the design
If I export a frame as an SVG, Figma adds a phantom rect element to the file that is not in the design.
Note if it helps troubleshoot: the bug doesn’t happen if you go to SVG export settings and check “Ignore overlapping layers”.
Please stop adding elements that shouldn’t be there; this is causing render artifacts for some of our products.
Jan 16, 2025 10:09 PM UTC
Hey ​@Brian_Olson, thanks for flagging this!
Be sure to uncheck Show in exports for Fill to prevent the rectangle from being added to your SVG export.
Brian_Olson
Jan 17, 2025 5:12 PM UTC
Thanks for the suggestion. I gave it a try. Unfortunately, the phantom rect is there regardless of whether I have “Show in exports” checked in the frame’s fill settings.
Jan 17, 2025 5:36 PM UTC
Thanks for following up, ​@Brian_Olson!
Noted. This is definitely not expected behavior in that case. I’ll send this over to the team to investigate.
Brian_Olson
Jan 17, 2025 5:40 PM UTC
Thanks, dvaliao!
