'Paste to replace' not working in Prototype mode
  • January 28, 2025
  • 29 views
James_Garnham
If I click on a prototype link, in prototype mode, it highlights a stronger blue colour. I then want to paste and replace (which to my mind should be CMD + SHFT + OPT + V) but instead use weird shortcut CMD + SHFT + R and...absolutely nothing happens… I can paste (CMD+V) but cannot paste to replace in Figma any way - is this a bug?
Gayani_S
  • 2096 replies
  • January 28, 2025
Hi ​@James_Garnham, thank you for reaching out! I understand how frustrating it must be when a shortcut doesn’t work as expected.
I came across a forum post that might help:
https://forum.figma.com/archive-21/is-it-possible-to-copy-paste-prototype-interaction-33970?postid=20533#post20533
I was able to get it working using this approach. Could you take a look and let me know if this aligns with what you're trying to do? If not, I’d be happy to dive deeper to make sure I fully understand your issue and help you find a solution.
Looking forward to hearing back from you, thank you!
James_Garnham
  • 14 replies
  • January 28, 2025
Hi, Yep I saw that approach but I’m working on a file with 100s of interactions that I need to quickly change, to be opening the interactions menu and doing that is a real sadness… I appreciate the response though. Surely CMD + SHFT + OPT + V as per copying and replacing an object with a paste in design mode should be in play here within Prototype mode…? Is there any reason you know of why this cannot/shouldn;t be the case?
