Files on the board are not displaying or glitching
  • May 13, 2025
  • 13 views
Sanya Sem
Hello !
I’m facing an issue where, on my work computer (both in the web and desktop versions of Figma), the files on the workspace board are not showing up. They can be selected but don’t appear visually. I’ve cleared the cache and checked for errors but couldn’t fix it. The problem only occurs on this specific computer—everything works fine on others.
How can I resolve this?
Browser: [Your browser name, if relevant]
OS: Windows 11"
  • Figmate
  • May 16, 2025
Hi ​@Sanya Sem ,
I get that the objects on your canvas aren't showing up when you open files on your work computer.
Let's try a bit of troubleshooting together. First things first:
  • If you're using a VPN, firewall, or proxy, could you try turning them off temporarily to see if that makes a difference?
  • Try disabling your browser extensions one by one to see if any of them might be interfering?
  • Would you also mind trying to connect to Figma using a different network, like your phone's hotspot, just to see if the problem continues?
If one of the above does the trick, then the issue is likely with your work network setup. In that case, I'd recommend reaching out to your IT team so they can take a deeper look at your environment. You can let them know about these resources, which might help them:
Hopefully, this helps you figure out what's going on.
Thanks!
