Tarek-MetaCTO
Aug 1, 2025 6:47 PM UTC
Figma MCP not working
I have Figma MCP enabled but whenever I go to the MCP server URL I see the following response
{"jsonrpc":"2.0","error":{"code":-32001,"message":"Invalid sessionId"},"id":null}
Tom Reem
Tom ReemSolution
Aug 13, 2025 4:55 PM UTC
Hi everyone,
I really appreciate you taking the time to share your updates here. I’ve passed your latest replies along to our product team to keep your experience front and center.
A couple of points to help clarify next steps:
  1. If you see the following error, this is coming from the Cursor side. It may turn red after 5 minutes, but it should still function. If you can see “5 tools,” it should be connected.
    Figma MCP Cursor test % curl -s http://127.0.0.1:3845/mcp || echo "Connection failed"
  2. If you’re seeing errors in your MCP clients, screenshots of where those appear will help us better understand the behavior — feel free to reply here or send those in directly.
If you’d like a member of our Product Support team to take a closer look at your specific file, please reach out to them directly and include:
  • the link to this Forum thread for context
  • a full-size screen recording of the issue (if possible)
  • a link to the affected file
  • edit access for support-share@figma.com
Thanks again for your patience — your reports are a big help in improving things
Takausr A.
Aug 12, 2025 10:32 PM UTC
Figma MCP Endpoint Issue - /mcp endpoint not working, only /sse works
SUMMARY
Despite Figma Desktop indicating that the MCP server is running at the /mcp endpoint, only the /sse endpoint is functional. The /mcp endpoint consistently returns JSON-RPC errors.
ENVIRONMENT DETAILS
- Figma Version: 125.7.5 (latest as of August 12, 2025)
- Operating System: macOS
- MCP Server Port: 3845 (confirmed running)
- Installation: Fresh reinstall to ensure no version conflicts
What Works:
- SSE Endpoint (http://127.0.0.1:3845/sse):
  - Returns HTTP 200 OK
  - Content-Type: text/event-stream
  - Proper security headers
  - Establishes connection successfully
  - MCP tools function correctly through this endpoint
What Doesn't Work:
- MCP Endpoint (http://127.0.0.1:3845/mcp):
  - Returns various JSON-RPC errors depending on request format
  - Common errors encountered:
    {"jsonrpc": "2.0", "error": {"code": -32001, "message": "Invalid sessionId"}, "id": null}
    {"jsonrpc": "2.0", "error": {"code": -32000, "message": "Invalid request body for initialize request"}, "id": null}
TECHNICAL INVESTIGATION
Server Status Verification:
I confirmed that Figma is running the MCP server on port 3845 and VS Code can connect to it via the SSE endpoint.
Endpoint Testing Results:
- SSE Endpoint: curl -v http://127.0.0.1:3845/sse returns HTTP 200 OK with proper event-stream content
- MCP Endpoint: curl -X POST http://127.0.0.1:3845/mcp with standard JSON-RPC requests returns error messages
TROUBLESHOOTING STEPS ATTEMPTED
1. Clean Installation:
   - Completely uninstalled and reinstalled Figma Desktop
   - Downloaded latest version (125.7.5) from official website
   - Verified no old MCP installations remained
2. Configuration Cleanup:
   - Removed all third-party MCP installations
   - Cleared MCP-related caches and configurations
   - Ensured no port conflicts
3. Multiple Request Formats Tested:
   - Standard MCP initialize requests
   - Various JSON-RPC parameter combinations
   - Different HTTP headers and content types
4. Process Verification:
   - Confirmed Figma process is running the MCP server
   - Verified port 3845 is correctly bound to Figma
   - Established that VS Code can connect via SSE endpoint
CURRENT WORKAROUND
The SSE endpoint (/sse) works perfectly and provides full MCP functionality. MCP configuration that works:
```json
"Figma Dev Mode MCP": {
"url": "http://127.0.0.1:3845/sse"
QUESTIONS FOR FIGMA TEAM
1. Is the /mcp endpoint fully implemented in version 125.7.5?
   - The endpoint exists but returns errors for standard MCP requests
   - Are there specific authentication or session requirements?
2. What is the expected request format for the /mcp endpoint?
   - Standard JSON-RPC 2.0 requests fail with "Invalid request body"
   - Is there additional metadata or headers required?
3. Should we continue using the /sse endpoint?
   - It works reliably but may be deprecated
   - What is the migration timeline if any?
4. Are there any known issues with the MCP endpoint in the current version?
   - This could help other developers experiencing similar issues
Please clarify the expected behavior and provide guidance on:
1. Proper usage of the /mcp endpoint
2. Whether /sse will remain supported
3. Any additional configuration required for /mcp endpoint functionality
Thank you for your attention to this matter. The MCP integration is valuable for design-to-code workflows, and clarifying this endpoint behavior would help the developer community.
Tom Reem
Tom ReemSolution
Hi everyone,
Malcolm Paul
Aug 14, 2025 5:07 PM UTC
For those stuck until Figma can figure things out. Try: https://github.com/GLips/Figma-Context-MCP
Please be careful of setting up third party MCPs and sharing your Figma token with them.
Of course. But I still need to get work done. The /sse and /mcp endpoints don’t work. I also use motiff.com and their MCP server works perfectly fine.
Until Figma fixes this, I’m actually getting work done using the tool above. If it’s not fixed before I’m done then I’ll just use the tools that actually work.
新海 许
Aug 18, 2025 10:30 AM UTC
  1. Only http://127.0.0.1:3845/sse can access,and http://127.0.0.1:3845/mcp can’t access
  2. Although http://127.0.0.1:3845/sse's OPTIONS, GET responds normally, tools such as get_code report errors,error code:500
            - "OPTIONS /openapi.json HTTP/1.1" 200 OKTom ReemTom Reem
            - "GET /openapi.json HTTP/1.1" 200 OK
            - INFO - Calling endpoint: get_code, with args: {'clientLanguages': 'xml', 'clientFrameworks': 'android'}
            - INFO - Unexpected error calling get_code
            - "POST /get_code HTTP/1.1" 500 Internal Server Error
Please help to check it, thanks~
新海 许
Aug 18, 2025 10:37 AM UTC
​@Tom Reem
  1. Only http://127.0.0.1:3845/sse can access, http://127.0.0.1:3845/mcp still can’t access.
  2. Although http://127.0.0.1:3845/sse's OPTIONS, GET responds normally, tools such as get_code report errors. error code: 500
Gabriel Williams
Aug 18, 2025 5:59 PM UTC
This seems like an expired token or auth. I had Claude Code “Reconnect” and things started working again with /mcp.
Sivasankar M
Aug 19, 2025 11:08 AM UTC
Just for your information, guys — in my case, when I try the /mcp endpoints using the get_code tool in VS Code, I encounter a timeout error. Other tools are working fine. Could this be related to a server-side issue?  Anyone finds a solution on this.
Nick Pape
Aug 19, 2025 3:33 PM UTC
This still seems broken. VSCode 1.103, fresh Figma installation, dev seat, started the MCP, get the toast that it’s running, but then see the following:
VS Code:
2025-08-19 10:31:17.945 [info] Starting server figma
2025-08-19 10:31:17.948 [info] Connection state: Starting
2025-08-19 10:31:17.949 [info] Starting server from Remote extension host
2025-08-19 10:31:17.989 [info] Connection state: Running
2025-08-19 10:31:18.062 [info] Connection state: Error Error sending message to http://127.0.0.1:3845/mcp: TypeError: fetch failed
2025-08-19 10:31:18.062 [error] Server exited before responding to `initialize` request.
Config:
    "figma": {
// The Figma MCP server requires you to setup the local client.
// 1. Install the rich client: https://www.figma.com/downloads/
// 2. Login with a "Dev" account
// 3. Enable the MCP: Upper left Figma menu -> Preferences -> "Enable Dev Mode MCP Server"
// 4. Click start above "figma" (above this comment).
"type": "http",
"url": "http://127.0.0.1:3845/mcp"
If you nav to the endpoint in a browser, you get:
Aug 20, 2025 4:34 PM UTC
Hey All, thanks for following up!
As ​@Tom Reem mentioned previously, when you’re testing using CURL or in the browser, you’ll receive the Invalid sessionId, because you’re not passing in a session ID as a parameter. While MCP clients do allow this, it’s not designed to be used directly. Again, this is an issue on the Cursor side of things. Even if it goes red after a few minutes, it should still work.
Again, for direct one on one support with this, we encourage you to reach out to our support team directly and provide screenshots of exactly where in your MCP clients the errors are popping up: https://help.figma.com/hc/en-us/requests/new
xiao99xiao
Sep 6, 2025 6:26 AM UTC
👍 This works for me.
