Tarek-MetaCTO
Aug 1, 2025 6:47 PM UTC
Figma MCP not working
I have Figma MCP enabled but whenever I go to the MCP server URL I see the following response
{"jsonrpc":"2.0","error":{"code":-32001,"message":"Invalid sessionId"},"id":null}
Tom Reem
Tom ReemSolution
Aug 13, 2025 4:55 PM UTC
Hi everyone,
I really appreciate you taking the time to share your updates here. I’ve passed your latest replies along to our product team to keep your experience front and center.
A couple of points to help clarify next steps:
  1. If you see the following error, this is coming from the Cursor side. It may turn red after 5 minutes, but it should still function. If you can see “5 tools,” it should be connected.
    Figma MCP Cursor test % curl -s http://127.0.0.1:3845/mcp || echo "Connection failed"
  2. If you’re seeing errors in your MCP clients, screenshots of where those appear will help us better understand the behavior — feel free to reply here or send those in directly.
If you’d like a member of our Product Support team to take a closer look at your specific file, please reach out to them directly and include:
  • the link to this Forum thread for context
  • a full-size screen recording of the issue (if possible)
  • a link to the affected file
  • edit access for support-share@figma.com
Thanks again for your patience — your reports are a big help in improving things
mattcarpenter
Aug 1, 2025 11:16 PM UTC
Same issue for me. The figma desktop app showed a banner indicating that I was still using the old endpoint and suggested switching to the new sse endpoint. I did so but was unable to connect after changing it.
.mcp.json for claude code:
"figma" : {
"type": "sse",
"url": "http://127.0.0.1:3845/mcp"
The old /sse endpoint still works.
moontown
Aug 2, 2025 7:36 AM UTC
Same here
Tarek-MetaCTO
Aug 2, 2025 8:18 AM UTC
Same here
Despite being deprecated, add the URL to be /sse instead of /mcp, this will give deprecation warning inside Figma but it’ll work just fine. Hopefully they fix it soon
A.P.
Aug 2, 2025 6:08 PM UTC
This worked for me for Claude Code. Using the official instructions (with the URL set to /mcp) did not work, but changing it to /sse has made it green)
iqdda
Aug 3, 2025 7:39 AM UTC
Absolutely love how they released breaking change on Friday evening. Vibe coders all the way through!
Tom Reem
Aug 4, 2025 1:15 PM UTC
Hi everyone — thank you for flagging this! I’ve shared your reports with our engineering team, and they’ve identified the cause of the issue. An investigation into a fix is currently in the works, and we’ll follow up here as soon as we have more to share.
Appreciate your patience in the meantime — and don’t hesitate to reach out if anything else comes up.
James Blackwell
Aug 4, 2025 1:25 PM UTC
Also managed to get this working just by changing the URL to http://127.0.0.1:3845/sse
Tom Reem
Aug 4, 2025 7:51 PM UTC
Hey everyone — good news. I checked in with the team working on this, and the issue has now been resolved. There was a problem in the setup documentation, but it’s been corrected — everything should work as expected now. ✅
💡 Next steps:
  1. If you were running into this while using the setting in Claude Code, you’ll need to remove the old MCP server config first: claude mcp remove figma-dev-mode-mcp-server.
  2. Then, re-add it using the steps with this address http://127.0.0.1:3845/mcp outlined in the updated Figma Learn guide: Guide to the Dev Mode MCP Server.
⚠️ Reminder: /sse is deprecated and will stop working in the future.
Appreciate everyone’s patience while we worked on this! Let us know how things go — and feel free to reach out if anything else comes up.
Tangtang8982
Aug 5, 2025 1:47 PM UTC
When using  http://127.0.0.1:3845/mcp
and when i use  http://127.0.0.1:3845/sse
the agent load the prompt (get_code for example) to infinity..
Thank’s for your help
Levi_Jones
Aug 6, 2025 6:04 AM UTC
​@Tangtang8982 check your hidden LLM instructions file. This was the fix for me with Claude Code https://x.com/Levidjones/status/1952958415086711118
