Aditi Bagal
Feb 10, 2026 10:55 AM UTC
Figma cursor is dramatically bigger
Hi, the figma cursor used to be small and neat. In the past few days it has suddenly grown much bigger and it glitches in the middle of work switching back to the original smaller size, and growing again when moved or used for an action. Any idea why this is happening?
Gayani_S
Gayani_SSolution
Apr 1, 2026 9:35 AM UTC
Hey everyone, thanks so much for flagging this!
We’ve seen several reports of this happening in Firefox, and the team has now rolled out a fix. Refreshing your tab should apply it, and your cursor + mouse interactions should return to normal.
If you’re still seeing this after a refresh or if you’re running into it on a different browser, let me know your browser and version and I’ll take a closer look with you.
Елена М
Apr 29, 2026 1:11 PM UTC
Large cursor issue on Huawei MatePad using mouse. Interface scale doesn't help. Started recently.
Gayani_S
Apr 29, 2026 2:09 PM UTC
Hey everyone, thanks for continuing to flag this!
Quick update: I’ve shared this with the team internally and they’re now aware and actively looking into it. I’ll keep an eye on this thread and share updates as soon as I have them.
Really appreciate your patience while this is being investigated. In the meantime, you please try using Chrome or Edge, or switch to the Figma Desktop app.
meenakship
May 8, 2026 4:34 AM UTC
Just wanted to add in that I have the same issue, huge  pixelated cursor that makes it impossible to select small pieces of design. Hopefully it’s resolved soon
sMao
May 11, 2026 8:28 AM UTC
I need to add something no one has mentioned about Screenflow screen recording: when I use Screenflow to record my own actions the mouse appears normal, but in the recorded video the cursor inside the Figma canvas becomes very large. The layer list on Figma’s left and the properties panel on the right are fine; only the canvas area’s cursor is hugely enlarged, and every cursor state in the canvas is enlarged.
I tested both the browser and the client and they have the same issue: only Safari doesn't enlarge the icon, but I also noticed that Figma’s cursor is blurry in Safari, so I suspect Figma recently changed their vector cursors. I hope this can be fixed soon, and that screen recording software (Screenflow) will also work correctly.
The GIF image shows the screen captured by ScreenFlow after recording
Gayani_S
May 11, 2026 11:48 AM UTC
Hey both, really appreciate you taking the time to flag this and the screen recording.
I’ve passed everything along to the team so they can investigate further, including the behavior you’re seeing across different environments and with Screenflow.
I’ll share any updates as soon as I hear back.
For anyone else coming across this issue, please try using Chrome or Edge, or switching to the Figma Desktop app.
Gayani_S
May 12, 2026 5:26 PM UTC
Hey everyone, quick update! The team has rolled out a fix for this, and it should be fully resolved by tomorrow. This addresses the reports from users on Windows, Ubuntu, and Android.
​@sMao since you’re seeing this specifically when using ScreenFlow, this appears to be related to how ScreenFlow handles cursor recording rather than a Figma issue. ScreenFlow tracks and re-renders the cursor during editing, which can cause it to appear oversized.
In the meantime, here are a couple of things you can try:
  • Resize the cursor directly within the ScreenFlow editor
  • Try another screen recording tool (e.g. QuickTime or OBS), which don’t show this issue
Let us know if you’re still running into problems after the fix rolls out, happy to help further!
Tibooooo
May 13, 2026 6:08 AM UTC
Thanks ​@Gayani_S and the Figma Team, I can confirm it actually works on Ubuntu 22.04, the cursor is back to its normal size now.
meenakship
May 15, 2026 3:52 AM UTC
Here confirming mine (Ubuntu 22.04.5 LTS) also has come back to the normal size. Thank you guys!! ​@Gayani_S
sMao
May 27, 2026 9:56 AM UTC
Hey, thanks for your reply.😋
I retested this issue carefully and rigorously. After using a process of elimination, I still believe this is a Figma issue. It may be a small issue that your team has not noticed yet, but it is very important to me. The enlarged cursor makes it impossible for me to properly demonstrate Figma workflows, as shown in my previous reply.
I’ll briefly explain my testing process and how I narrowed the issue down.
Environment:
Latest macOS 26.4.1
To check whether this was a ScreenFlow issue, I uninstalled the latest version and reinstalled several versions for testing:
Version history: https://www.telestream.net/screenflow/versions.htm
- Latest version 10.5.2, released in February 2026
- Version 10.5, released in August 2025
- Version 10.0, released in 2021
- Older version 9.0.8, released in 2022
Test result:
All of the versions above reproduced the issue where the Figma cursor becomes enlarged.
Specific behavior:
(a) The enlarged cursor only appears in the canvas area.
(b) The cursor size appears normal in the left file list and the right-side properties panel.
Cross-device verification:
(a) Mac Studio M1: The tests above were performed on this device, and the issue was confirmed.
(b) MacBook Air M4: With the same system version and testing method, the issue still occurred.
As far as I remember, before at least 2025, recording Figma with ScreenFlow worked normally and this issue never occurred. Since I also tested ScreenFlow versions from as far back as 2022 and the issue still appeared, this strongly suggests that the issue is not caused by ScreenFlow.
I know that Figma customizes cursors for different states, so I also tested other canvas-based tools such as tldraw and Miro. They also use custom cursors, but all of them worked normally.
By the way, FigJam has the same issue as Figma. I even tested Figma in browsers, and the cursor also became enlarged there. However, there was one exception: Safari. In Safari, the cursor appears normal in screen recordings, but I can clearly see that the cursor graphic is very blurry. For example, it looks like a small bitmap image being scaled up.
Combined with the results from testing other canvas-based tools, I can also visually tell that their cursors are somewhat blurry, while the latest version of Figma does not have this blurriness issue.
So my guess is that this may be related to Figma having updated these cursor graphics. I actually really like this cursor update in Figma, because I prefer to enlarge the cursor in macOS System Settings, which used to make Figma’s cursor blurry. With the new Figma cursor, it is finally sharp.
However, based on the issue I am reporting here, I suspect that something may not be configured correctly in the code. I hope this feedback can provide some useful reference for your team when investigating and fixing the issue. I’m really looking forward to seeing this problem fully resolved.
sMao
May 29, 2026 3:44 AM UTC
​@Gayani_S Hey, here ↑
