Aditi Bagal
Feb 10, 2026 10:55 AM UTC
Figma cursor is dramatically bigger
Hi, the figma cursor used to be small and neat. In the past few days it has suddenly grown much bigger and it glitches in the middle of work switching back to the original smaller size, and growing again when moved or used for an action. Any idea why this is happening?
Gayani_S
Gayani_SSolution
Apr 1, 2026 9:35 AM UTC
Hey everyone, thanks so much for flagging this!
We’ve seen several reports of this happening in Firefox, and the team has now rolled out a fix. Refreshing your tab should apply it, and your cursor + mouse interactions should return to normal.
If you’re still seeing this after a refresh or if you’re running into it on a different browser, let me know your browser and version and I’ll take a closer look with you.
Samir_Kushwaha
Apr 1, 2026 9:48 AM UTC
Thanks! Can confirm it’s fixed now
Stef9016
Apr 15, 2026 7:39 AM UTC
Hello,
J’ai le problème du curseur trop grand, je suis sous linux avec Firefox.
Tibooooo
Apr 15, 2026 9:02 AM UTC
As of now, I have the same problem with Firefox on Linux. Didn’t have that until last week !
Gayani_S
Apr 15, 2026 10:23 AM UTC
Hey both, thanks for calling this out!
Could you share which Firefox version you’re using, along with your Linux OS version? That’ll help us report this properly to the team and investigate what might have changed.
In the meantime, as a workaround, you could try using Chrome or Edge, or switch to the Figma Desktop app while this gets looked into.
Stef9016
Apr 15, 2026 11:10 AM UTC
Ubuntu 22.04.5 LTS
Firefox 149.0.2 (64 bits).
Thanks you.
Tibooooo
Apr 15, 2026 2:08 PM UTC
Yep, exactly the same config :
Firefox 149.0.2 -64 bits) on Ubuntu 22.04.5 LTS.
I’ll use Chrome instead for a while. Thank you fo investigating !
iqqqbbbal
Apr 22, 2026 4:26 AM UTC
Ubuntu 22.04.5 LTS
Thanks you.
yes the same thing happend to me
Gayani_S
Apr 22, 2026 1:09 PM UTC
Hey everyone, I see you’re all hitting this with the same setup!
I’ve passed these details along to the team so they can investigate what’s going on here.
Really appreciate your patience while we dig into this. I’ll share an update here as soon as I hear back!
Martin Lindelof
Apr 24, 2026 5:55 AM UTC
Issue is persistent on android tablets. It is due to Figma using a custom cursor, other applications that keeps the system cursor works just fine.
Checked all settings, page zoom default. Desktop web page mode. Accessibility settings disabled. Everything checked,
A perfect solution would be if Figma had a settings to use system cursor and not custom ones. It could be on by default, and us that works on tablets could opt out and keep the system cursor and miss out on some of the features custom cursor come with.
Christel_Agier
Apr 28, 2026 9:29 AM UTC
Hi,
Issue is still active on ubuntu 22 and firefox 150.
