Eslam3
Nov 1, 2024 5:49 PM UTC
Exceeding Memory Usage
Hey, I’ve got an issue with one of my projects regarding exceeding memory usage and I’ve been trying to use components as much as I can to reduce the file size but it’s not helping!
I’ve been following the same logic for years now and haven’t seen this issue before. Is there a way of fixing this? What should I do?
DameGeri
Nov 2, 2024 10:30 AM UTC
Hi Eslam3!
I had the same issue with one of my projects – even after compressing photography and simplifying illustrations, the file was still too large. In the end, I had to split the project across multiple files - this was the only effective solution that worked for me at the time. Once I separated the content, everything ran much more smoothly.
Probably not the answer you’re looking for I’m afraid! Eek!
Eslam3
Eslam3Author
Nov 2, 2024 11:32 AM UTC
That’s what I’ve reached in the end not to lose any of the files but it’s not making any sense. There’s definitely something wrong
DameGeri
Nov 2, 2024 12:43 PM UTC
I was surprised when this happened - I thought there was no limitation in regards to memory. Here’s a Figma article about reducing memory usage in files: Reduce memory usage in files – Figma Learn - Help Center
