Annotations appear on Design mode
Jin S Kim
If you see the screenshot that I attach, the annotations appear in Design mode. I believe that they should appear only in Dev mode. Please advise how I can fix this situation.
Nellya
  • 524 replies
  • April 4, 2025
Are you sure these annotations were added using Annotation tool? The design looks a bit off. Can you select one of them and check if they are visible in the layers panel?
Jin S Kim
  • 6 replies
  • April 5, 2025
@Nellya Thans for your comment. Yes, these annotations were added using Figma’s Annotation tool. The design is visible in the Layers panel as you can see in the attachment. What do you mean by “The design looks a bit off”? What do you see?
Nellya
  • 524 replies
  • April 5, 2025
Jin S Kim wrote:
@Nellya What do you mean by “The design looks a bit off”? What do you see?
Design of Figma annotations looks a little bit different than yours. Can you select one of your annonations and show the full screenshot with layers?
Jin S Kim
  • 6 replies
  • April 6, 2025
@Nellya Is the screenshot what you asked? It looks the same as what you attached.
Nellya
  • 524 replies
  • April 7, 2025
Try this
