Variable: Mode visibility
  • February 6, 2025
  • 10 views
Alessandra_Ciancio
In the administration panel, you can manage the default modes for each workspace (image attached).
Is there a way instead to also manage the visibility of modes by workspace?
Example: The library has ‘Mode 1’ and ‘Mode 2’. For workspace B - we set ‘Mode 2’ as the default mode and prevent Mode 1 from being visible. In a file in that workspace, the designer will only get the library in Mode 2 and will not be able to switch to Mode 1.
Thanks
  • 2325 replies
  • February 12, 2025
Thanks for reaching out. Unfortunately, the feature you referred to is currently unavailable. The only workaround I can suggest at this time is to segregate teams using different modes, which may not be realistic in this scenario.
Therefore, I changed the category as "Submit a Feature" for future improvements.
Thanks for your understanding!
