How to rerun the plugin without UI
  • January 31, 2025
  • 85 views
elcicneha
I’ve used multiple plugins where after you run it the first time, there comes an option on the right sidebar to rerun the plugin, but this time it runs with the previous settings, without launching the UI.
How can I add that functionality in my plugin?
Best answer by tank666
To add a relaunch button in Figma UI, you need to add a manifest.relaunchButtons array with commands, then use the plugin code to set it to some node using the setRelaunchData() method and write code for the relaunch button command handler.
For example:
manifest.json
  "relaunchButtons": [
      "command": "relaunch",
      "name": "Relaunch"
code.js
figma.root.setRelaunchData({relaunch: ''});
if (figma.command === 'relaunch') {
    // do something
else figma.showUI(__html__);
  • 4870 replies
  • January 31, 2025
For example:
manifest.json
      "name": "Relaunch"
code.js
    // do something
