Celine_Solution
Hi @Almas_Hamzat ,
Your objects in your left side bar are in purple because they are under the Component
Capture d’écran 2023-04-28 à 16.07.02
Celine_Solution
Hi @Almas_Hamzat ,
Shubh_Aggarwal
February 16, 2024
What does it mean being under the component?
February 26, 2024
To ungroup elements, you can select the group in the Layers panel and use the command “Ctrl + Cmd + G” on Mac or “Ctrl + Alt + G” on Windows. Alternatively, you can choose “Object” in the top menu and select “Ungroup.”
Components are elements you can reuse across your designs. They help to create and manage consistent designs across projects.
You can create components from any layers or objects you’ve designed. These could be a whole range of things like buttons, icons, layouts, and more.
You can grasp overview of Components
Please check out the help center article:
Figma Learn - Help Center
Hope it helps!
Toku
