Jaclyn_Hsiung
Nov 1, 2023 9:48 PM UTC
What does Smart Animate mean in code?
Smart Animate is a great feature for designer but how is it translated when Dev receives this? I am able to find the following code for an on/off toggle component:
// On click
// Change to: "State=On";
// Animate: Smart animate;
animation-timing-function: cubic-bezier(0.45, 1.45, 0.8, 1);
animation-duration: 300ms;
// On click
// Change to: "State=Off";
When developer see the line “Animate: Smart animate;”, will this make sense for them when they write in code?
Celine_Solution
Nov 3, 2023 4:03 PM UTC
Hi Jaclyn_Hsiung,
Thanks for reaching out to the community.
After checking internally with the Dev Team, to give you some clarification, the lines that start with // are simply comments that don’t have impact on how the code behaves.
While the other lines are generated code based on the parameters of the animation. It’s likely that for a dev // Animate: Smart animate; won’t be meaningful, as it’s a Figma design term. But the rest defines the animation in CSS terms. Hope this helps!
Celine_Solution
Hi Jaclyn_Hsiung,
Jaclyn_Hsiung
Nov 3, 2023 7:03 PM UTC
Thanks Celine!
Yevgen Gorbunkov
Mar 18, 2025 11:58 AM UTC
This issue does not appear to be solved.
Provided answer suggests that `animation-timing-function` and `animation-duration` lines define animation, whereas those lines only provide information about duration of animation (300ms) and the way animation progresses through each cycle (`cubic-bezier()`). However, the type of animation (is it fill/scale/opacity/position/rotation changed) and specific parameters (e.g. are we scaling target element by 5% or by 7%; are we making it 53% or 64% transparent; etc ) remain unknown.
Hence the question: is there a way for devs to access all the necessary parameters to implement it identically to prototype?
