Urgent Help Needed: Components Not Syncing Properly
Isaac_Forman
Dear Figma Community,
I am facing a major issue with syncing components in a Figma file, and I’m hoping someone here can help me out. I have a file that is not syncing properly when I make updates to the component library. Specifically, when I publish changes, the review changes prompt appears, but when I click “Update,” not all instances of the component are updated. This is happening for multiple components.
After some investigation, I noticed that in the libraries for the current file area, the component library I’m using keeps getting unchecked. This is a significant problem because both the library and the file I’m working on are quite massive and complex, so creating new files is not really an option.
I have tried everything I can think of to fix this issue, but nothing seems to be working. If anyone has experienced a similar problem or has any suggestions for how to fix it, please share your insights. Any help or guidance would be greatly appreciated.
Best answer by Gayani_S
Hi Isaac, thank you for flagging this! I’d recommend you to reach out our support team. They will be able to help you out here.
Gayani_S
  • March 30, 2023
Ngan_Vo
  • July 28, 2023
I’m facing the same problem and it’s making me quite tired to find a quick solution especially in the time when I need to quickly edit my design to update the times for the Dev team.
Can anyone support me, pls? ☹
Kai Smith
  • March 17, 2025
The recommendation was to contact Support.
What was the outcome?
Is there anything to share - we are facing the same problems
