Unable to import fs, TypeScript, in Figma
moondrip909
WHAT I WANT TO ACCOMPLISH
Please excuse my poor English.
I want to output CSV files for items such as Text in Figma, but I wanted to separate the files, so I used this as a reference to set up ts-loader and webpack.
I am new to developing Figma plug-ins, but I managed to complete the process of compiling text and other items and outputting them to the console.
After that, I encountered an error where the output in CSV would use fs, but here I encountered an error where fs could not be imported.
THE PROBLEM AREA
//The problem area
import * as fs from 'fs'; // Here!!
export class DownloadCSV{
    public save(filename: string = "out.csv"){
        fs.writeFileSync(filename, this.text);
//manifest.json
  "name": "XXX",
  "id": "1338758441514588489",
  "api": "1.0.0",
  "main": "dist/main.js",
  "capabilities": [],
  "enableProposedApi": false,
  "editorType": [
    "figma",
    "figjam"
  "ui": "dist/ui.html",
  "networkAccess": {
    "allowedDomains": [
      "none"
package.json
  "name": "XXX",
  "version": "1.0.0",
  "description": "XXX",
  "private": true,
  "scripts": {
    "analyze": "npx webpack --mode production --profile --json > profile.json && npx webpack-bundle-analyzer profile.json build",
    "build": "npx webpack --mode production",
    "build:watch": "npx webpack --mode development --watch",
    "lint": "npx eslint",
    "prettier:format": "npx prettier --write 'src/**/*.{js,jsx,ts,tsx,css,json}'"
  "author": "",
  "license": "",
  "devDependencies": {
    "@figma/plugin-typings": "^1.85.0",
    "@types/express": "^4.17.21",
    "@types/node": "^20.11.20",
    "ts-loader": "^9.5.1",
    "typescript": "^5.3.3",
    "webpack": "^5.90.3",
    "webpack-cli": "^5.1.4"
  "dependencies": {
    "@types/fs-extra": "^11.0.4",
    "@types/react": "^18.2.60",
    "@types/react-dom": "^18.2.19",
    "@types/three": "^0.161.2",
    "react": "^18.2.0",
    "react-dom": "^18.2.0",
    "three": "^0.150.1"
//tsconfig.json
  "compilerOptions": {
    // Three.jsがES5未サポートなので、割り切って比較的新しい仕様でビルドする
    "target": "ES2015",
    // TSのモジュールはES Modulesとして出力
    "module": "ES2015",
    // JSXの書式を有効に設定
    "jsx": "react-jsx",
    // node_modules からライブラリを読み込む
    "moduleResolution": "node",
    // これの設定も必要 デフォルトインポートの有効化
    "allowSyntheticDefaultImports": true,
    // 厳密モード
    "strict": true,
    "lib": [
      "ES2023",
      "DOM"
    "typeRoots": [
      "./node_modules/@types",
      "./node_modules/@figma"
  "include": ["src/**/*.ts"],
//webpack.config.js
module.exports = {
    // モード値を production に設定すると最適化された状態で、
    // development に設定するとソースマップ有効でJSファイルが出力される
    mode: 'development',
    // ↓コメントを解除すればビルド時のエラーは消えますが、Figma実行時に「requireが使われている」というエラーが発生します。
    //target: 'node',
    // メインとなるJavaScriptファイル(エントリーポイント)
    entry: './src/main.ts',
    output: {
        //  出力ファイルのディレクトリ名
        path: `${__dirname}/dist`,
        // 出力ファイル名
        filename: "main.js"
    module: {
        rules: [
                // 拡張子 .ts の場合
                test: /\.(js|ts|tsx)$/,
                //exclude: /node_modules/,
                // TypeScript をコンパイルする
                use: 'ts-loader',
    // import 文で .ts ファイルを解決するため
    // これを定義しないと import 文で拡張子を書く必要が生まれる。
    // フロントエンドの開発では拡張子を省略することが多いので、
    // 記載したほうがトラブルに巻き込まれにくい。
    resolve: {
        // 拡張子を配列で指定
        extensions: [".ts", ".tsx", ".js", ".json"],
        //modules: [`${__dirname}/src`, 'node_modules']
    // ES5(IE11等)向けの指定(webpack 5以上で必要)
    target: ["web", "es5"],
PROBLEM/ERROR MESSAGE BEING ENCOUNTERED
//console
PS C:\Users\XXXX> npm run build
Debugger attached.
> plugin@1.0.0 build
Debugger attached.
Debugger attached.
assets by status 2 KiB [cached] 1 asset
orphan modules 4.52 KiB [orphan] 3 modules
./src/main.ts + 3 modules 5.94 KiB [built] [code generated]
ERROR in ./src/DownloadCSV.ts 1:0-25
Module not found: Error: Can't resolve 'fs' in 'C:\Users\XXXX\src'
  Parsed request is a module
  using description file: C:\Users\XXXX\package.json (relative path: ./src)
    Field 'browser' doesn't contain a valid alias configuration
    resolve as module
      C:\Users\XXXX\src\node_modules doesn't exist or is not a directory
      looking for modules in C:\Users\XXXX\node_modules
        single file module
          using description file: C:\Users\XXXX\package.json (relative path: ./node_modules/fs)
            no extension
              C:\Users\XXXX\node_modules\fs doesn't exist
            .ts
              C:\Users\XXXX\node_modules\fs.ts doesn't exist
            .tsx
              C:\Users\XXXX\node_modules\fs.tsx doesn't exist
            .js
              C:\Users\XXXX\node_modules\fs.js doesn't exist
            .json
              C:\Users\XXXX\node_modules\fs.json doesn't exist
      C:\Users\node_modules doesn't exist or is not a directory
      C:\node_modules doesn't exist or is not a directory
 @ ./src/SearchScreen.ts 2:0-38 13:20-36
 @ ./src/main.ts 1:0-37 36:24-39
webpack 5.90.3 compiled with 1 error in 2429 ms
Waiting for the debugger to disconnect...
WHAT I TRIED
I have searched for 2 weeks on stackOverflow and other sites to find the cause, but I am frustrated.
I am wondering if Figma and Webpack are incompatible, but I have no idea what the cause is or how to fix it. I have no idea what the cause is or how to fix it, so I am asking for your advice on what I should do.
Thank you in advance for your answer!!
ADDITIONAL INFORMATION (FW/TOOL VERSION, ETC.)
node v20.11.0
Hi,
I tried to resolve the same issue of yours and found that it seems impossible to export data files directly from Figma plug-in.
So I made a simple server which just saves data from Figma plug-in into local files. My test Figma plug-in extracts and sends the data to the server using Figma’s Fetch APIs.
I hope this would help you.
Chaitanya_Rajguru
I am facing the same issue, and think that the ‘fs’ module is not available in the Figma console, because:
> const fs = await import('fs');
returns the error:
Uncaught TypeError: Failed to resolve module specifier 'fs'
@YoonHo_Lim your solution seems very useful. Would you be able to share more details / pointers about how you created the server and about the fetch() API call you used?
Thanks!
