Svinozilla
Jul 29, 2026 9:01 PM UTC
Toggle layer visibility bug?
I’m experiencing a very strange and specific bug with the Layers panel visibility toggle.
What happens
  1. I click the eye icon on any layer to hide it, this works normally.
  2. After that single click, if I simply hover the mouse over other layer names (not on their eye icons), those layers also turn off one by one.
  3. The only way to stop it is to click anywhere on the screen.
  4. It feels like the “click and drag to multi-toggle visibility” feature is getting stuck in the “button still held down” state after a normal click.
It happens in every file (not file-specific).
A friend checked on his machine and does not have this issue, so it appears to be local to my setup.
When it started
I was working normally. I left the computer running for about 2 hours (no updates, no crashes, nothing unusual). When I returned, the bug was there and has stayed ever since.
What I’ve already tried
  • Restarted the PC
  • Cleared Figma cache
  • Tested in different browsers + Incognito
  • Unplugged my mouse, launchpad and XP-Pen tablet
  • Confirmed it’s not Windows ClickLock
Nothing has fixed it.
I recorded a short video that clearly shows the behavior.
Has anyone else run into something like this? Any ideas what could cause the Layers panel to get stuck in multi-toggle mode after a normal click?
adamsmasher
adamsmasherSolution
Jul 30, 2026 5:10 PM UTC
Hello everyone! Thank you all for your patience while our team investigated the issue. This has now been resolved - you’ll want to refresh if you are using the browser, and make sure you’re using the latest version of the desktop app (go ahead and reload your tabs if you already are). Let us know if you have any issues!
Daniel Schultheiß
Jul 30, 2026 9:47 AM UTC
Same issue here as well. Figma V126.7.10. Cant work like that. Whenever showing or hiding one element and if I then hover over others - that action gets applied to all of them when hovered as well. Oh it happens in the browser as well..not only in the app.
SergeySergeev
Jul 30, 2026 10:19 AM UTC
Hello,
I encountered what appears to be a bug with layer visibility toggling.
Expected behavior
Clicking the visibility (eye) icon should toggle only that layer.
If I want to toggle multiple layers, I should have to keep the mouse button pressed while dragging over additional eye icons.
After releasing the mouse button, dragging the cursor should not continue toggling visibility.
Actual behavior
  1. Click the visibility (eye) icon of any layer.
  2. Release the mouse button.
  3. Move the cursor over other eye icons in the Layers panel.
The visibility of every eye icon that the cursor passes over continues to toggle, as if Figma still thinks the mouse button is being held down.
The issue stops only after clicking somewhere else in the interface.
Environment
  • Windows 11
  • Latest desktop version
  • Also reproduced in the web version
  • Also reproduced in Incognito mode
  • Reproduced in every file (new and existing)
  • Reproduced with multiple mice
  • Reproduced after launching an older Figma version
  • Windows itself does not show any mouse button issues (tested outside Figma)
What I already tested
  • Different mouse
  • Different USB ports
  • Desktop app
  • Web app
  • Incognito mode
  • Older Figma version
  • Multiple files
  • New empty file
  • ClickLock is disabled in Windows
  • Mouse behaves normally in other applications
The problem only occurs inside Figma.
I have attached a short screen recording demonstrating the issue.
Thank you.
Svinozilla
Jul 30, 2026 10:27 AM UTC
Support team is investigating. Let’s hope they will fix it asap.
We've identified an issue on our side that's causing the trouble you’re having with showing and hiding your layers, we're currently looking into this to find out what's causing this to happen.
I've linked your ticket to our investigations so our team can see you're also impacted by this and as soon as we have any more updates on this we'll let you know!
Gayani_S
Jul 30, 2026 10:59 AM UTC
Hey everyone, thanks for all the detail you've shared here!
Just to confirm, we've identified this as an issue with layer visibility toggling in the Layers panel, and our team is actively investigating what's causing it.
I don't have a timeline yet, but I'll post here as soon as there's an update. Thanks for bearing with us!
shnotsh
Jul 30, 2026 11:03 AM UTC
Reproducible both on Desktop macOS and web. That’s what happens when you rely on AI for development. Keep vibecoding.
speedcakes42
Jul 30, 2026 11:19 AM UTC
When clicking AND RELEASING on the layer visibility icon, the app will behave as if I were holding down click and any layer I mouse over will toggle visibility. Just began today July 30, 2026, so whatever this newest version of Figma windows desktop is. Currently having to use keyboard shortcut to toggle visibility states.
Jul 30, 2026 11:57 AM UTC
Same here. Started experiencing it on Figma desktop (win) all of a sudden. I am on an urgent task now and I can’t work like this... Please and please and please fix it as soon as possible!
jaejae
Jul 30, 2026 12:33 PM UTC
slopcoded
Milney
Jul 30, 2026 2:16 PM UTC
Have an issue that started today where if I click to lock or hide a layer in a ‘Design’ window and then move my mouse not holding the button down, it then starts locking or hiding any layer the mouse icon moves over. No idea why it's doing it. Or if I've adjusted a setting!
Does anyone have any idea why it’s doing it?
Milney
Jul 30, 2026 2:19 PM UTC
Same thing happening here. It's very frustrating when trying to work!
