ivan_guidea
Apr 19, 2022 8:23 PM UTC
Styles applied to text layers or component instances get detached at random
We are experiencing a weird issue in Figma where library “Text Styles” applied to text layers or component instances get detached on random.
Our fix is to use a semi-automated way of selecting all text layers on a screen and then perform the “Reset text style” action.
The issue is persistent and seems to happen at random - anyone experienced something similar before?
There is a closed topic on what seems like the same issue, with no resolution provided - Text Styles randomly get detached from original file
Tia_Escobar
Jun 3, 2022 7:05 PM UTC
@Josh My team just experienced this issue… components with text styles are detached. How do we resolve it?
Brian_Saunders
Jun 23, 2022 12:55 PM UTC
I am pretty sure this one is happening again. I can’t figure out what actions are causing it, but all my text styles are getting detached over and over again and it’s very frustrating. The text styles are not local, they’re coming from a published library.
Tingting_Cheng
Jun 23, 2022 2:47 PM UTC
Been having the same issue, very annoying. No idea what triggers it, but what has helped me to quickly match styles again is the plugin called Design Lint, you’ll be able to select all layers with missing styles and match them again all at once.
Brian_Saunders
Jun 25, 2022 1:26 PM UTC
Thank you for this suggestion! I hope the problem gets fixed.
Andrew16
Jun 27, 2022 3:25 AM UTC
Still problematic! This makes entire design systems unusable!! No matter if it’s library’ed or local.
Can someone from Figma please actually consider this a priority problem?
Just to illustrate concern since 2021 ~
Alice_Holm
Jul 5, 2022 9:24 AM UTC
I have the same problem within the variants.
0xtutti
Jul 6, 2022 2:58 PM UTC
I was wondering if this was me being sloppy or a Figma issue.
I’m also encountering this even after the fix was deployed. Seems it’s still a running issue.
VarunYellina
Sep 14, 2022 11:11 AM UTC
This has been an issue for quite some time. Is @Figma looking into this? This problem is further aggravated for our developers who normally use the style name to build the text components in code. They keep coming back to us asking what is the text style.
@Figma I don’t want any new features until this is fixed. Please prioritize stability over everything else.
Sep 14, 2022 4:31 PM UTC
Hey All,
The team is still tracking this issue, but there’s no exact timeline for a fix.
For now, the two workarounds they suggest are:
  • Manually swapping the dangling/unlinked instance to another instance of the component
  • Going back into version history, finding a version of the file where the instance is not dangling, restoring that version as a new file, and then copying and pasting the frame with those instances back into the working file
Jordan_Smith2
Oct 3, 2022 5:35 AM UTC
I’ve been having this issue as well. Lots of occurrences lately, not just on variants but also regular frames. I’ve just had almost a whole page get detached – very frustrating.
@dvaliao if there’s any way to push this further up the priority I’m sure many people would appreciate it.
