Niclas_Lundberg
Jul 3, 2024 5:17 PM UTC
[Solved] Need help on how to do bulk insert
I have hundreds and hundreds of small images (600x900) on the canvas.
I need to place all of these into individual frames, where the parent fram should be 600x900 and have a reasonable padding that I can add a color to on all frames.
In the end I want all pictures centered and in a “fill” setting across all frames.
Is there any tool or plugin or trick I can use achieve this without spending hours doing it manually?
Niclas_Lundberg
Jul 4, 2024 8:30 AM UTC
I solved it by using a plugin to first add a frame to all images individually
Then I had all images be set to “fit”
Then I added auto-layout to all frames
Then I added a black background to the parent frame and had around 48px padding on all edges
Problem solved
