Curtis_Giberson
Jul 17, 2024 1:58 AM UTC
Slides: Bug: Embedding prototype with multiple flows it won't let me change flows in the slide
I embedded my first prototype in Figma Slides. It added the file easily enough. But I have 3 different flows in the prototype. I’m trying to queue up flow 2 or 3 but when I go to present it always shows the first flow. There’s a dropdown under Interaction in the right toolbar to choose any of the flows in the Slides interface. But it always presents the first flow no matter which flow I choose in that dropdown.
Aug 8, 2024 6:23 PM UTC
Hey @Curtis_Giberson, thanks for reaching out and sorry for the delayed reply!
Are you still having issues switching between flows with embedded prototypes?
When you have the prototype selected, you should see the ability to switch between your flows in the right sidebar:
Screenshot 2024-08-08 at 11.20.42 AM
Aug 12, 2024 6:19 PM UTC
Try placing all of your prototype flows on the first page of the Figma file. This seems to fix the issue for us otherwise it will default to the first page only regardless of whether a prototype is present or not.
Aug 12, 2024 11:07 PM UTC
I can confirm - I am having the same issue. I built a slideshow about 2-3 weeks ago, with multiple different prototypes/flows embedded throughout. Now, when I load the slideshow, every single prototype only loads the first flow. I updated the software, restarted, restarted my OS, etc… nothing has corrected the issue
Aug 13, 2024 3:57 PM UTC
Were you able to get it to work by placing the prototypes on the top most page of the Figma file? This seems to consistently work as a solution for me so far. 🤞
Aug 13, 2024 5:17 PM UTC
I did this, yes … but I’d call that a work-around. Would rather have it working as it did before.
Klara_Barova
Aug 14, 2024 5:14 PM UTC
Im having the same issue. Even though I can switch flows in the sidebar, the flows in the slide will only display the first one after re-loading and I cant stop them from re-loading. Quite a shame since I spent multuple hours building the presentation for client and will have to re-do it elsehow. And placing the prototype into the first oage of Figma file does nothing for me unfortunatelly.
Rich3
Mar 17, 2025 5:23 PM UTC
I have my prototypes on different pages in the figma source file, and if i close the slide file and reopen it…. then the prototype embed changes to another prototype.
