Replacing an image/video by copy/paste from desktop now renames the layer?
  • August 28, 2024
  • 5 replies
  • 175 views
Stephen_Moy1
If I use “ctrl + c” to copy a file from my computer, then select the layer in Figma I want to update and use “ctrl +v” to paste/replace it. The layer will inherit the name of the file on the desktop. So if it’s “IMG_ASD123” the Figma layer changes to be named this instead of what it was labeled in Figma.
Is this a recent update? It never used to happen?
It’s a bit frustrating as I used to name my layers “Asset (3:4)” or whatnot to indicate to dev what the ratio of the asset was but now I need to keep renaming it everytime I copy/paste a new assets onto the layer.
Is there a way to disable this at all?
Thanks in advance! 🙂
Elad_Rahmin
  • October 8, 2024
Noticed it too, and this is a very annoying change.
  1. I pasted an image onto a main component’s fill and it changed my component’s name to be called image.
  2. I pasted an image to a variant, and all the props names got ruined because now the variant was renames to image.
    Took me a long while to understand why it happened.
    And then I saw anywhere I pasted an image I now had tons of components/layers called image, when I specifically gave them descriptive names before.
dvaliao
  • 4603 replies
  • October 9, 2024
Hey All, thanks for flagging this, @Stephen_Moy1!
Apologies also for the delayed reply. I was able to repro on my end, so I’ve flagged this over to the team to investigate.
I’ll provide an update as soon as I can.
Stephen_Moy1
  • 13 replies
  • October 9, 2024
Amazing @dvaliao, it’s a strange one - I thought it was just be going mad ha.
Thanks for flagging to the team to investigate.
All the best,
Steve
Phu_Nguyen
  • Active Member
  • 37 replies
  • December 5, 2024
It’s 2 month and still see this happening. I have just see the issue in my file. Super frustrating.
dvaliao
  • 4603 replies
  • December 5, 2024
