Yoann1
May 14, 2024 10:55 AM UTC
Remove all auto-layout
Hi,
I like to work with auto-layouts but i work with Figma newbies and sometimes when they work with components i’ve worked on, they get overwhelmed.
Is there a quick way to remove every auto layout of all frames selected or contained in a frame ?
Because it can be very tedious to remove them one by one.
zachshea
zachsheaSolution
May 14, 2024 6:01 PM UTC
The Destroyer plugin does this and more!
Figma
May 14, 2024 4:58 PM UTC
Hi there, welcome to the community!
As a workaround, you can select all the auto-layout in your left panel for example, then use the shortcut: ⌥Option + ⇧Shift + A . Hope this helps!
zachshea
zachsheaSolution
Figma
Yoann1
Yoann1Author
May 15, 2024 8:13 AM UTC
Thank you for your reply, but since you can’t select both the frame and the frames inside of it, I think it is still a bit of a painfull process
May 15, 2024 9:22 AM UTC
Thanks for the feedback, I understand the frustration. I will share it to the internal team.
(And also, thank you for sharing this plugin @zachshea !)
Yoann1
Yoann1Author
May 15, 2024 10:11 AM UTC
Thank you, i forgot to look into plugins !
Ofir_K
Sep 9, 2024 2:42 PM UTC
What is the combination over Windows?
Thanks
Sep 9, 2024 2:48 PM UTC
Hey @Ofir_K ,
For Windows, you can use this shortcut: Alt⇧ ShiftA.
Ofir_K
Sep 9, 2024 3:11 PM UTC
Thank you for your quick reply!
Kyle_Jackson
Oct 8, 2024 6:36 PM UTC
You can do this natively / without a plugin by selecting the parent frame then opening the actions menu (command/option + /) and typing in “Remove all auto layout”, press enter once the “Remove all auto layout” appears.
