DBeguin
Sep 6, 2024 10:34 AM UTC
Problem with swap style
Hello,
I published my new library, I added it at another file, and I wanted to do a swap with this new library, but it doesn’t work. I don’t understand why?
Thank you in advance for your responses.
PS - I do not yet have the new version of Figma.
Sep 9, 2024 4:53 AM UTC
Hi there,
Thanks for reaching out! Could you double-check the following?
Before you swap, make sure:
  • The current file you’re working from contains at least one instance or style that you wish to swap, and the asset is from a different library.
  • Both libraries involved in the swap (the library being replaced and the soon-to-be-used library) are published to team libraries.
  • Any assets you wish to swap have matching names.
If you’re okay with this, could you clarify which steps you’re getting stuck on? You can check the steps from the help center article:
Figma Learn - Help Center
I hope we can find a solution for this.
Thanks!
Toku
DBeguin
DBeguinAuthor
Sep 9, 2024 3:24 PM UTC
Hello,
I understood my error, I had not published the two libraries, it could not work …
thanks for your help
