Bogriceanu_Sorin
Jan 12, 2024 12:38 PM UTC
[PLUGIN API] Link TextNode characters to component property
I am developing a little Figma plugin using the Plugin API.
I am working with a TextNode withing a Component.
The component has a TEXT proprety configured.
I am tring to link the content of the text node to the value of the component’s proprety using the API
Below is the exact UI functionality that I am aiming for.
Screenshot 2024-01-12 at 14.34.37
I haven’t found anything that would help in the Plugin API refference.
Can you guys point me in the right dirrection?
10x
tank666
tank666Solution
Jan 12, 2024 12:58 PM UTC
figma.com
tank666
tank666Solution
Bogriceanu_Sorin
Jan 12, 2024 1:12 PM UTC
I went trough all the specs for TextNode and Component event did a deep dive with the console debugger… no luck…
If I look at a node where I set this from the console, it appears as a bound variable to the “characters” key of the TextNode, but if I try to use setBoundVariable(“characters”, propID) it fails.
tank666
Jan 12, 2024 1:24 PM UTC
Sorry, but what does variable binding have to do with it? You want to apply the component’s text property, right? The componentPropertyReferences property of the TextNode, to which I left a direct link in the previous post, is what you need.
Bogriceanu_Sorin
Jan 12, 2024 4:17 PM UTC
my mistake… I missread the link on the phone. It scrolled to top and missed the point.
Just tried it now. Works!
Many thnaks!!!
Sorin
Finnian_Langham
Oct 24, 2024 1:50 AM UTC
@Bogriceanu_Sorin Hey, I’m trying to achieve this same thing. Can you share your code? I’m not clear on how to create new componentPropertyReference item.
tank666
Oct 24, 2024 4:16 AM UTC
TextNode.componentPropertyReferences = {characters: 'TextPropertyName#0:1'};
