Passing Code.JS or Code.TS values/variables to UI.HTML
D_S
Hello! I’m currently working on a plugin and I’m trying to pass the Font Size value to display within my Plugin UI. I’m retrieving the value via const selection = figma.currentPage.selection["0"].fontSize; but I can’t seem to get it to display within my plugin UI. I’ve tried document.getElementById('font_field').innerText = (figma.currentPage.selection["0"].fontSize); but no luck.
My main goal is to actually just pass the value to a tensor flow script that’s working within my html doc but to also display it within the UI.
How do I communicate between the two files? : )
Thank you!!
Best answer by tank666
You must send the message using postMessage.
figma.com
tank666
figma.com
D_S
  • July 6, 2021
Worked like a charm, thank you!
Leonardo_Ratzlaff1
I’m using postMessage
figma.ui.postMessage({ type: 'results', updatedComponents}, '*');
but I get the following error:
Uncaught DOMException: Blocked a frame with origin "null" from accessing a cross-origin frame.
