Ruud_Walraven
Sep 16, 2024 3:19 AM UTC
Nested async calls never return
I wrote a plugin that is working fine. But when I try to refactor some code into functions the same functionality stops to function. It seems that any code I place into nested async functions never return a value. I also tried the “then” syntax.
Is this a known issue and how do I resolve this?
In the example below async function updateElements() is an async function nested in a function that is already async. Any await figma.... does not return (so it is not just this function). This sin’t really covered in the documentation I read, for example Asynchronous Tasks | Plugin API
async function updateElements() {
    console.log('This line appears in console, indicating the function is executed');
    const colorVariable = await figma.variables.getVariableByIdAsync('VariableID:2:492');
    console.log('Never get\'s here');
figma.ui.onmessage = async (msg: { type: string, background: string, color: string }) => {
    if (msg.type === 'update-elements') {
        const colorVariable = await figma.variables.getVariableByIdAsync('VariableID:2:492');//this works
        console.log(colorVariable); // Contents are displayed in console
        await updateElements();
Ruud_Walraven
Sep 16, 2024 4:49 PM UTC
I figured out how to solve the immediate issue:
I initially followed the quickstart guide here: Plugin Quickstart Guide | Plugin API which creates a tsconfig.json:
  "compilerOptions": {
    "target": "es6",
    "lib": ["es6"],
    "strict": true,
    "typeRoots": [
      "./node_modules/@types",
      "./node_modules/@figma"
When I change strict so it reads strict: false, then the code works as expected
