Claire Fredrick
May 30, 2025 9:13 PM UTC
Measurement Indicator Will Not Go Away
I can’t seem to find a way to turn off the red measurement tool. If I go to View > Hide UI it does remove it, but it also removes other side navigation components that I need available.
Junko3Solution
Jun 2, 2025 3:38 AM UTC
Hi ​@Claire Fredrick,
I understand you're looking to hide those measurements from your canvas. That's definitely possible.
Please try following these steps:
  1. Click  Figma icon on the top left to open the main menu.
  2. Hover over “View” in the dropdown.
  3. Deselect “Annotations”.
I tested this on my end, and it should hide both annotations and measurements for you. You can find more details in our article here: Add measurements and annotate designs
Aranza
Jun 9, 2025 12:01 AM UTC
Same, I ended up cutting and pasting everything in the same frame, and that finally removed the measurement tags, hope Figma fixes this soon.
Slava_Bronevitskiy
Jun 9, 2025 7:16 PM UTC
This is incorrectly market as “SOLVED”. It is not solved. There is a bug where indicators cannot be removed. It’s not about hiding all. It’s about deleting a single measurement indicator while keeping the rest.
impactby.design?ref=nI
Mmediong Esu
Jun 11, 2025 6:04 PM UTC
Still happening
Payton_Biddington
Jun 11, 2025 9:13 PM UTC
Yep, still happening. You can hide them, but can’t delete…
Mike D
Jun 12, 2025 8:52 PM UTC
Still happening for me too. I did find a workaround that seems to be a permanent fix, though a clunky one: If I click on the annotation (like a measurement) and hit delete, nothing happens at first. But if I do that, then close and reopen the app, the annotation is gone. Not exactly efficient — but better than a sharp stick in the eye.
Matteus da Costa
Jun 13, 2025 12:23 PM UTC
It's buggy!!!!
When I try to delete is does not go away...
When I try to move it, does not move and retrieves back to the original position…
The workaround: To apply the changes I made, I have to reload the tab I every.single.time 🙄
Matteus da Costa
Jun 13, 2025 12:24 PM UTC
hey ​@Junko3, please review the new comments.
Jeremie_Passebon
Jun 13, 2025 12:59 PM UTC
There is a bug! We cannot permanently remove the measures
cartino
Jun 16, 2025 3:02 PM UTC
​@Junko3 Also calling for this to be re-opened. Measurements can be hidden, but still don’t appear to be individually removable.
krcheon
Jun 17, 2025 4:27 AM UTC
I can't delete it. It's so inconvenient.
