Claire Fredrick
May 30, 2025 9:13 PM UTC
Measurement Indicator Will Not Go Away
I can’t seem to find a way to turn off the red measurement tool. If I go to View > Hide UI it does remove it, but it also removes other side navigation components that I need available.
Junko3Solution
Jun 2, 2025 3:38 AM UTC
Hi ​@Claire Fredrick,
I understand you're looking to hide those measurements from your canvas. That's definitely possible.
Please try following these steps:
  1. Click  Figma icon on the top left to open the main menu.
  2. Hover over “View” in the dropdown.
  3. Deselect “Annotations”.
I tested this on my end, and it should hide both annotations and measurements for you. You can find more details in our article here: Add measurements and annotate designs
Lara O.
Jun 17, 2025 3:05 PM UTC
Same - its really inconvenient. Please fix.
Jun 18, 2025 9:17 AM UTC
Hi there,
I understand you are experiencing difficulty deleting measurements.
Typically, to delete a measurement, you can click it and press the Delete or Backspace key, as outlined in this article.
However, we are currently aware of a bug that may be affecting you:
Once you update an existing measurement, trying to delete it with the Backspace key just makes it revert to the original measurement, and it can't be removed.
Our engineering team is actively working on a resolution for this issue. Sorry for any inconvenience this may be causing.
Evie_Zhang
Jun 19, 2025 4:43 PM UTC
Hi there,
For added clarity: pressing the Delete key reverts the item to its original state rather than removing it.
This is a significant bug that creates uncertainty for users when interacting with the feature. Please prioritize fixing it.
Jun 23, 2025 11:05 PM UTC
Hey All, thank you for your patience!
Our annotations team pushed out a fix for this issue. Please refresh your tabs and let us know if you run into any further issues.
Seth_Annis
Jun 24, 2025 7:13 PM UTC
It works! 🎉
Please thank the development team
Jun 24, 2025 7:22 PM UTC
Glad to hear that, ​@Seth_Annis!
I’ll pass along your kind words to the team. 😊
Tim Greller
Dec 13, 2025 4:25 PM UTC
This only works in Dev Mode tho. The measurements are visible in Design Mode as well, but cannot be deleted there.
Dec 15, 2025 7:57 PM UTC
Hi ​@Tim Greller, thanks for flagging this!
I just tested this with a macOS in the browser and the desktop app, and I’m able to delete measurements as expected in both Dev mode and Design mode by simply selecting and pressing my delete key.
What OS are you using? Are you using Figma in the desktop app, browser, or both? And how are you attempting to delete the measurement?
With a few more details, our team can try to replicate and fix.
