Claire Fredrick
Measurement Indicator Will Not Go Away
  • May 30, 2025
  • 28 replies
  • 4220 views
I can’t seem to find a way to turn off the red measurement tool. If I go to View > Hide UI it does remove it, but it also removes other side navigation components that I need available.
Best answer by Junko3
Hi ​@Claire Fredrick,
I understand you're looking to hide those measurements from your canvas. That's definitely possible.
Please try following these steps:
  1. Click  Figma icon on the top left to open the main menu.
  2. Hover over “View” in the dropdown.
  3. Deselect “Annotations”.
I tested this on my end, and it should hide both annotations and measurements for you. You can find more details in our article here: Add measurements and annotate designs
Junko3Answer
Claire Fredrick
That did the trick! Thank you so much
Ashley M
I can hide measurements but I can never seem to select and delete permanently.  I can move the measurement up and down, but never actually select it and be able to delete it. Right click also doesn’t do anything. This doesn’t seem right.
andrewc
+1 - I can add but can’t delete measurements, which seems like a bug.
Anthony11
I also can’t delete a measurement
Seth_Annis
Same problem here. When trying to delete the measurement it reset to origin but can’t be deleted.
Jon_Landis
Also eager to know how to delete measurement annotations!
Simon ROUSSEL
Same
Karen D.
Also interested in knowing how to delete measurement annotations.
JustJest
Same, this seemed to just appear on a component and I have no idea how to delete it.
