SAME
May 22, 2024 8:10 PM UTC
Issue with Custom Text in Dropdown Menu Components
I created a dropdown menu in Figma. When I copied the components and opened the dropdown menu to customize the text, I noticed that the preview still showed the original component’s text. However, when I set the component to be open on the new frame, the preview displayed as expected with my customized text.
This is the main component
This is the component I copied to the frame
This is the preview effect (not the 222 I expected)
SAME
SAMESolution
May 24, 2024 8:11 PM UTC
Finally, I added contents to text 111 in the main component so that the text can be changed in the design field of the copied component.
ksn
May 24, 2024 6:42 PM UTC
Hey @SAME - would you be able to share a copy of your file/library with us so we can try to replicate on our end (and also look at the details of your design)?
If not, that’s totally fine. If you are able to, can you please do the following:
  1. File a ticket this link: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
  2. Share edit access to the file with support-share@figma.com – you won’t be charged for doing this. Please also include the name of this file in the body of the ticket you file.
Let me know once you’re able to do that.
SAME
SAMEAuthorSolution
