Is there a way to assign multiple variable to one component?
I’m creating a contact web app (for NDA purposes I’m not using exacts, just getting close). There are several types of contacts the user can create, location, person, and item are examples. The user will have the option to search for contacts and apply advanced filters. For example, the user will be able to filter contact type, search for keywords, and use advanced filters for things like “First name - Contains - sam” (like mail rules)
I would like to make the prototype as flexible as possible. So if the user searches for “Macy” it should return all contact types with that value. If the user wants to only see locations that have “Macy” they would select the Location option as the contact type. Then if they wanted to apply more filters they could add a rule that says “City - Contains - York” Then would see all Locations with Macy in the result that also have York in the city field.
I would love to be able to assign multiple variables to an element. Then as a tester uses the prototype to apply predefined filters, it hides elements that don’t have true values for each variable. For example: locations that contain a match for “Macy” but “City - Does not contain - York” are not shown. If I could apply multiple variables or user component properties or something like them to make contact cards visible or not that would be great.
It could be used widely with any type of “multiple conditions must be met to…” scenario.
Does anyone know if something like this is possible now?
