Alex_FG
Sep 1, 2023 4:20 AM UTC
Is it not possible to set a text variable to an empty string?
I can set it to ’ ’ (a space), or any string with text in it, but nothing happens if the value I give it is ‘’.
Alex_FG
Alex_FGSolution
Sep 5, 2023 9:42 AM UTC
I think I was setting it to null instead of ‘’. Setting it to ‘’ worked.
Alex_FG
Alex_FGAuthor
Sep 1, 2023 5:12 AM UTC
nvm it’s a bug on my end 🤓
Sep 5, 2023 9:19 AM UTC
Hey! How did you fixed it? I have the same problem 😦
Alex_FG
Alex_FGAuthorSolution
Martin_Mateos_Sanchez
Jan 6, 2024 4:27 PM UTC
Hello! Which ASCII character are you referring to as ‘’? Right now, I can only set it to a whitespace for the variable to appear as empty (although it isn’t, since it’s a whitespace and has a length of one)
Captura de pantalla 2024-01-06 172436
tank666
Jan 6, 2024 5:02 PM UTC
You need to set it to an empty string without any character.
variable = '';
Jan 6, 2024 5:35 PM UTC
Oh, is that using the API? Or is there a way using the keyboard? Because if the variable is set to a whitespace and I delete it and press intro, the variable resets to the whitespace. Similarly, if I create a new text variable, which by default is set to “String value” and I try to delete that completely and press intro, the variable resets to “String value”
So weird
tank666
Jan 6, 2024 5:41 PM UTC
Only using the Plugin API. I wrote about it here:
May 6, 2024 11:34 AM UTC
Hey, I am not able to do it. Can you explain it a bit more ? How do I set a string’s value as null
tank666
May 6, 2024 3:49 PM UTC
You cannot set null as a value for a string variable. Instead of null, you must specify an empty string.
variable.setValueForMode(modeId, '')
Joseph_Kaguri
Jul 18, 2024 1:48 PM UTC
Hi, could you share the full code that you added on Run plugin API to set a String variable empty?
