Kailous
Dec 19, 2024 5:03 AM UTC
I came up with a method to assign keyboard shortcuts to functions that don’t have them
Some functions that don’t appear in the menu cannot have shortcuts assigned to them. However, I came up with an alternative method. By using the keyboard shortcut Command+K, you can bring up the search box. Once the required function is entered, you can activate it. Then, on macOS, you can use a script to help automate this workflow and trigger it with a single click. Below is the script I wrote for quickly creating multiple components.
tell application "System Events"
    -- Activate the Figma application
    tell application "Figma" to activate
    -- Simulate the Command + K keyboard shortcut
    keystroke "k" using {command down}
    delay 0.1 -- Wait for the command panel to appear
    -- Type "创建多个组件" (Create Multiple Components)
    set the clipboard to "Create Multiple Components" -- Use the clipboard to ensure proper Chinese input
    delay 0.1 -- Ensure clipboard content is set properly
    keystroke "v" using {command down} -- Paste the clipboard content
    -- Press the Enter key
    delay 0.1 -- Wait for the input to complete
    keystroke return
end tell
Then, use automation settings to bind the script to a keyboard shortcut or a Touch Bar button, and you’re good to go.
However, I still hope that the official developers can adapt these shortcuts, or at the very least provide a function entry in the system menu to make it easier for users to set shortcuts using third-party tools.
