How to create a scrollTo to a word inside a Textbox?
Raphael_M
2024-01-15_10-44-41
Hi, all. I want to ask if is there a possible way to make a scrollTo event on a specific word/string in a textbox? For links, it’s possible by pasting the link after highlighting the text. I’m also open for any work-arounds that is possible in an Auto-layout.
Thank you!
Haroll
  • Active Member
  • January 15, 2024
Hello @Raphael_M
You cannot select a part of a text block to create an interaction. But you have work-arounds
Multiple text block :
Create multiple text block in order to ____ the one you want to interact with
(cons : this won’t work well on a multi-line text)
Absolute invisible element
You can position a rectangle with a 0% opacity and add the trigger on itself
(cons : whenever you change the text, you’ll probably have to reposition the invisible rectangle)
Raphael_M
  • January 16, 2024
Hi, Thanks for your reply.
You’re right with the use of multiple text blocks in an auto-layout wont work well on multiple lines. I’m thinking if is there is a Figma feature like putting a [# + Frame_Name] or something like that in adding links in the create link feature, which apparently doesn’t work or there is something missing on it.
If it works like the <a> in HTML, I’m thinking if it works like <a href="[link/#+yourframename">.
Using an invisible element in absolute position will not be a good idea because it’s going to be manually adjusted whenever I change screen sizes after all the text will be in an auto-layout.
Haroll
  • Active Member
  • January 16, 2024
Unfortunately, to my knowledge there is no such things in Figma. Maybe some plugins offer it but I don’t know any.
