How does small caps work in Figma with Google Fonts
Leonardo_Ratzlaff1
Using fonts like Source Sans Pro or Signika from Google Fonts in Figma gives you the ability to use small caps (among other OTF features).
But in code, small caps don’t work (the browser renders faux small caps).
How does Figma makes it work, and how can I make it work on my code?
tank666
  • 4862 replies
  • June 2, 2023
Leonardo_Ratzlaff
Thanks for the reply, but My problem is applying it to Google Fonts. It doesn’t work.
tank666
  • 4862 replies
  • June 2, 2023
I have tested the above fonts and it works.
Could you share the result of what you see when you apply font-variant-caps: small-caps?
Leonardo_Ratzlaff
This is what I’m facing. As you can see, it’s faux small caps (uppercase glyphs resized, and therefore thinner and ugly).
Leonardo_Ratzlaff
In Figma, I get the right visual.
tank666
  • 4862 replies
  • June 5, 2023
Figma uses a variable font which you can download here:
github.com
Try connecting the font from there instead of from Google Fonts to make sure it works correctly.
Leonardo_Ratzlaff
Oh, that will definitely solve the issue. I didn’t know it was an option.
Thank you so much, @tank666!
Kevin Camp
  • April 3, 2025
Alternatively - you can use a <span> to encapsulate the text to be in small caps and use a smaller font size.
e.g.   <p>S<span class=”smallCaps”>MALL</span> C<span class=”smallCaps”>APS</span></p>
