RizePoint_Product
Mar 2, 2023 9:25 PM UTC
How do I select all of the matching variants that Figma highlights?!
This has driven me BATTY for like two years. When I select a component Figma, correctly, selects the same component in other frames throughout my file. But neither “select all with same variant” or “select all with same component” will actually select the other purple instances highlighted.
What am I doing wrong? How do I select all of the instances Figma has identified?!
Stephane_Popout
Mar 5, 2023 2:02 AM UTC
The result you expect is not clear to me, so not sure to answer correctly
If you select an instance of a component & do “select all with same instance”
then all instances of this component will be selected
RizePoint_Product
Mar 6, 2023 4:20 PM UTC
Hi @Stephane_Popout,
My expected behavior is that only the instances highlighted in my initial screenshot–the ones with “Supplier (Required)” in the title–would be selected. However, using the “Select all with same instance” results in the following:
Which is not what I desired.
Figma clearly understands that all the instances highlighted in my original post are the same based on position/content/etc, yet there is no way that I’ve found to select just those versus selecting every instance on the page regardless of position/content/etc.
Stephane_Popout
Mar 6, 2023 11:58 PM UTC
Your using the same instances of component with different values for your dropdown text…
I don’t know an easy way to select them directly like that…
I can recommend a plugin that allow more complex selection → Similayer
Figma
To match your case I would
  1. select one of the instance
  2. open the plugin and select criteria “Other Variants” & “Position” (cf screenshot)
If you find how to do it without a plugin, I’d be glad to know it 🙂
RizePoint_Product
Mar 24, 2023 3:51 PM UTC
@Stephane_Popout I’ve tried Similayer before, but to your point the selection options aren’t granular enough for what I’m trying to accomplish. If they allowed selection based on a component property that would work, but alas, they do not.
What’s annoying is that Figma is clearly capable of making the selection I desire, since it recognizes and highlights the correct components in my first screenshot. But for whatever reason the Figma team hasn’t given us the ability to act on that. Sigh.
Abdul_Akbar
May 19, 2023 6:04 AM UTC
The same annoying issue on my end too. Does anyone have a solution for this issue?
AllieJ
Jul 14, 2023 2:40 PM UTC
I agree this is infuriating to see that Figma highlights the same element across all screens in prototyping mode but there’s no option to “apply interaction to all highlighted layers” or whatever it would be called.
I’ve used Similayer or ‘select all with’ to select them all first then apply an interaction. It seems like it should be part of the prototyping options though if Figma is highlighting them for me for no reason!
kmh
Aug 14, 2023 3:42 PM UTC
Wound up here during a search, because I figured there had to be a keyboard shortcut for this – it seems so obvious! Now at least I know I’m not missing anything.
Since the feature already exists halfway, it would be nice if the rest of it was included.
Jul 9, 2024 2:24 PM UTC
Bump, any luck so far? or is Figma not as airtight as i initially thought…
LINAS_STANIUKYNAS
Jul 12, 2024 8:06 AM UTC
I came here looking for a way to do this as well since Figma seems to show that it can with those purple borders. Hopefully they’ll see this and add it.
Joey_Bolohan
Dec 30, 2024 9:59 PM UTC
Select the component you would like hold shift and you will see all the other components related to it lightly highlighted then use your mouse click and drag across to select them all. Then you need to re-select the original one you selected by holding shift now you can paste and replace or manipulate however, you see fit.
Here is a loom on how to do it. Hope it helps let me know.
https://www.loom.com/share/bf3c0984a959430084096fe6ae137aee?sid=4405cf61-c1db-4084-b1d2-447e16eb4605
