ahmad_tabby
Mar 29, 2022 3:07 PM UTC
Figma Mirror app doesn't render the design correctly
When using mirroring on my phone, the design doesn’t show properly. Sometimes there are missing elements, or elements that are not fully visible.
This happens even when I open Figma Mirror on my phone’s browser.
Here’s how my design shows up:
I’m using the Samsung Galaxy S22 Ultra. Already tried re-installing the app and clearing the cache.
John_L
John_LSolution
Mar 22, 2023 6:27 AM UTC
Hi all,
We’ve pushed a fix that we think may help with the S23 issues you’ve reported. Can you let us know if things seem to be better or if you are still having trouble?
John
Brian_Warren
Nov 25, 2022 5:03 PM UTC
I am experiencing this issue as well on an S22. Most of the design renders correctly, but I have issues with some images and SVGs not showing up. Also some text occasionally as well.
Brian_Warren
Nov 25, 2022 7:11 PM UTC
This appears to only happen to elements that have interactions applied to them. For an example. I had a static button that rendered properly, but once adding an interaction to it, the text in the button no longer appears.
Marty_Meowsi
Jan 31, 2023 8:46 PM UTC
I’m having render issues on Xiaomi 12. I don’t believe this issue is fixed. Xiaomi 12 has Snapdragon 8 gen 1 processor.
gemmy
Feb 20, 2023 8:22 AM UTC
Any update? It’s a waste of time to “Exit” and “Begin mirroring” every now and then.
Jordan_Smith2
Feb 22, 2023 3:41 AM UTC
Still seems to be an issue. I’m having a lot of similar issues on my s23.
Vinizera
Feb 23, 2023 6:53 PM UTC
It has improved a lot but still occurs frequently, especially in frames with many elements.
Xiaomi 12 Pro.
Mar 6, 2023 5:48 PM UTC
I have a similar problem with s23 ultra both in browsers and in the native application. maybe there is a way to make figma work on s22 and s23?
Mar 6, 2023 6:00 PM UTC
Hey All,
While our mobile team does periodically check this thread, your best bet would be submitting a bug report directly to our team via the form here:
https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Mar 6, 2023 7:01 PM UTC
I did it, thank you.
TheKing
Mar 10, 2023 10:46 AM UTC
same issue on s23+
