m1n3g
Figma Make: React Warning: “React does not recognize the %s prop on a DOM element”
Both of my projects started showing this warning today while using Figma Make. The warning appears in the console and points to a React issue. Is anyone else experiencing the same issue?
Any insights or solutions would be appreciated.
Celyn_L
Celyn_LSolution
Hi everyone,
Our Engineering team has pushed a fix and confirmed that the issue has been resolved. Please refresh your files and let us know if you’re still experiencing any issues.
Thanks again for reporting this and for your patience!
Sanjana Danait
Hey everyone! Can you all try refreshing and see if things are working as expected again? There was a fix we pushed, and want to verify everything is well.
Seems to be working for me now! No more errors/warnings in the console and icons/buttons/dropdown styles are back to what they were earlier. Thank you!
m1n3g
m1n3gAuthor
The freezing issue still occurs when I click any dropdown on the screen.
Hi. Try making any prompt for your Figma Make, and then try clicking on the dropdown. Tell us what happens.
Eugene87
Same problem exists. System becomes iressponsive. Artifacts in the dropdowns still exist.
Tomasz Konik
Same thing with my project as well. Everything freezes, can’t do anything.
m1n3g
m1n3gAuthor
I contacted Figma support and they confirmed the team is currently investigating the issue causing the dropdown crash. There is no ETA yet, but they said they will share updates once a fix is available.
Product Claro
I'm still having the same problem. I lost the whole week :(
m1n3g
m1n3gAuthor
I can suggest a temporary method to avoid screen freezing when pressing the dropdown:
a. Create a custom component, such as a dropdown field and list.
b. Use a Popover + Dropdown + List combination. Avoid using the Radix Select component because it causes the screen to freeze.
Hope this helps others facing the same freeze issue.
Andres Prieto
I have the same issue here
After Creating a dropdown menu im having issues with the figma preview.
when I click on any dropdown menu on the design the figma make crash and freeze not responding and showing a grey background after I reload
I having warning with messages for asChild and _fgT, _fgS, _fgB.  and try solve the warnings as figma suggest but noting change
Figma Make Crash
Figma make Freeze
Critial Issue
My Figma Make freezes on certain elements. I found that it starts to freeze on Dropdown Items, which makes it impossible to work on the interface. when you deploy a project to Publish , everything is fine. But when you work through the Figma Make builder when I click a dropdown menu
