m1n3g
Figma Make: React Warning: “React does not recognize the %s prop on a DOM element”
Both of my projects started showing this warning today while using Figma Make. The warning appears in the console and points to a React issue. Is anyone else experiencing the same issue?
Any insights or solutions would be appreciated.
Celyn_L
Celyn_LSolution
Hi everyone,
Our Engineering team has pushed a fix and confirmed that the issue has been resolved. Please refresh your files and let us know if you’re still experiencing any issues.
Thanks again for reporting this and for your patience!
m1n3g
m1n3gAuthor
To this problem I can add another one. Now I can’t publish/update my prototype as well. Have some emergency. Hope it will be fixed very soon.
I didn’t have this issue on my site, but when I tap the dropdown, the whole screen freezes, including the pointer function.
Eugene87
Yes, this problem still exists.
Short review meeting to assess progress in receiving quality and forward progression.
Product Claro
I'm having the exact same problem on the site, not just with one, but with all the Figma Make files I had open. Less than an hour ago, the only copy that hadn't crashed yet stopped working. The same console errors, the same failure when activating any dropdown menu, and some icon buttons have changed size and color.
ksn
Hi everyone - I’m stepping in for ​@Celyn_L to let you know that we have a bug ticket filed for this, and our engineers are now working on addressing the issue.
We will update you as we learn more - thank you for your patience!
Sanjana Danait
> My Figma Make freezes on certain elements. I found that it starts to freeze on Dropdown Items, which makes it impossible to work on the interface.The styles have also changed (some elements have changed color, outlines have been added or removed, which I did not do).
I’m facing these exact same issues since last night. Trying debugging multiple times and nothing really fixes it so I suspect this is a FigmaMake bug. Just created a support ticket for this as well.
ksn
Hey everyone! Can you all try refreshing and see if things are working as expected again? There was a fix we pushed, and want to verify everything is well.
Just reloaded.  And everything froze again after click to Dropdown.
ksn
​@Boris Octalysis I just sent you a follow-up PM to touch base - thanks!
YuriiV
Tried to reload the page. Still the same issue – freezing after pressing dropdown.
Exago Team
Hello, here in Brazil we are also facing the same problem, still without a solution. We observed this afternoon that the warnings even freeze the interface, making it impossible to use.
⚠️ Warning: React does not recognize the `%s` prop on a DOM element. If you intentionally want it to appear in the DOM as a custom attribute, spell it as lowercase `%s` instead. If you accidentally passed it from a parent component, remove it from the DOM element.%s _fgB _fgb
