Nat_Tarbox
Aug 27, 2024 8:35 PM UTC
Figma app lag issues
Same issue here, M3 Pro mac / desktop app. Never had lag like this in Figma.
Cleared cache to no avail. Seems to have started after a recent update in the past week or so.
0xtutti
Sep 11, 2024 2:32 PM UTC
Experiencing similar issues.
I’ve cleaned the file, removed components, etc. Still some insane lag when doing small edits in components.
My only change is that I recently installed the update via homebrew.
Shubham_Kumar2
Sep 16, 2024 11:27 AM UTC
Same for me. Figma has started lagging a lot, to the point that even the simplest designs are inducing headache!
Franni
Sep 16, 2024 12:32 PM UTC
Me and my full team have problems with lags as well. We all use MacBook Pros.
In my case M2 Max, 16 inch, desktop app. We’re trying to build a prototype for user testing and it’s just not usable 😕 The file is new and not very loaded.
Edit: I tried using the browser app (Safari) and it’s just as bad.
I really hope you stop working on features nobody needs or is allowed to use (hello from Europe) and get Figma stable again + improve existing features we really need. At some point even big corps like mine will move on…
lukeratc
Sep 17, 2024 9:00 AM UTC
Same here, working nice and smooth on my 2021 14" M1 MBP but on my office based 27" intel iMac it’s slowing to an absolute crawl, even in new empty project files.
I’ve cleared cache, tried in different browsers rather than desktop app, and anything else that’s been suggested too. Project file I’m using right now says it’s utilising 5% memory, GPU usage of Figma Helper (GPU) is only 0.5% GPU and 0.0% CPU in Activity Monitor.
I am also using UI3 beta.
ksn
Sep 17, 2024 3:40 PM UTC
I’ve spoken with our support’s technical quality about this, and how to move forward. In reviewing all of your replies/reports with them, they request bug tickets be filed by each person affected by this individually (including your other affected teammates, if they are willing).
This form can be filled out here.
I totally understand that this may not be the answer you wanted from me directly, but we are concerned that there’s a common problem that is affecting all of you. Due to the limitations I have here on the forum, I unfortunately can’t be of more service here 😞 Individual accounts/files now need to be reviewed.
If you can file a ticket and then PM me to let me know you’ve done so, I can make sure it gets routed to the right place and looked at as soon as it can be.
lukeratc
Sep 17, 2024 4:33 PM UTC
Yep sure thing, I will do that. Thanks for your help!
Vincent_Schlothauer
Oct 1, 2024 8:49 AM UTC
I’ll add one more thing to this thread – while I appreciate the intention to cluster related bug tickets, I think it’s plain to see that this isn’t some singular technical issue across affected files that can be tracked down and eliminated. The features Figma has rolled out across the past 2-3 years simply aren’t stable or designed to handle any amount of complexity.
Figma components and Figma variables were very promising features initially, but they never seem to have made it out of their beta phase. It’s laughable that I can’t run a prototype on a 1.8GHz device (which are what our real users work with) because a single button press takes several seconds to trigger a response.
If Figma does not intend to roll out stable, functional solutions for components, variables and prototyping, then I wonder what kind of tool it strives to be in the long term. It does okay at handing off specs, but if that is all that can reasonably be expected, I could hand-annotate my designs like the good old days and probably still save money.
Nirbhay_Singh
Oct 9, 2024 9:37 AM UTC
I am also facing the same issue on desktop app. Looks like recent updates making app performance slower. They must improve the app as well to make it stable.
Isabella_Sampaio
Oct 14, 2024 3:46 AM UTC
Just to add to this thread, I’m also having perfomance issues on both web and desktop (Windows 10 and Mac M1). It was working great until the last updates or so. Hope this issue gets fixed soon.
Steponas_Dabuzinskas
Oct 16, 2024 3:24 PM UTC
Laggy here as well since recent updates.
So laggy that I might have to prototype on another tool.
