Portalle_Designer
April 15, 2021
Desktop app blank white screen/crash
Hello, after today’s update, there is a problem. After starting the figma, after about 1-2 minutes of operation, the entire application screen simply turns white. What could be the problem?
Matjaz_Torc
August 23, 2021
Same here. Problem with white screen tried all solutions above. @figma This is becoming unbearable… a paying customer with app that does not work!!!
Felix_Vasquez
August 24, 2021
Same problem here, after the last update! On desktop app, working fine on web.
Rukshan_Hettiwatte
August 27, 2021
I’ve been having this white screen/loading Figma logo issue for 3 days straight now…This is starting to get very frustrating since all of my college work/client work is hanging. @anon21722796 please provide a quick solution for this.
Mahdad_Mansouri
Same issue here white screen, happens in a sudden while I’m working!!!
64 bit windows 10
Joshua_Fillmore
September 2, 2021
Same problem here! Manage to log-in and make 4 or 5 adjustments then blank screen. Occurring in the web and desktop version (Windows).
vivekrevi
its been like this for me too for the past couple of days … am using the native app … am not using any other software at the same time … images won’t load or keeps flickering … too much ram consuming … i haven’t changed any files so drastically for the past couple of days, so it should consume this much of memory … about 60% and above … when tabs are switched, then the images are loaded again and a white screen for a while … basically, sluggish all over … using 15 plugins and among them, unsplash is the most common plugin I use … to test whether these images are causing problems, I created a new file with no image and its the same after couple of frames …
my build (all are updated to latest versions):
Win 10 Pro | 21H1 | 19043.1165
i7-6700K | 16GB
Radeon RX 480 | 8GB
Hakan_Reis
September 7, 2021
I have the same issue and it seems to be on certain hardware. I have a fairly new Dell with an integrated graphics card. After loading it works for ~30s then blink and locks. Closing the tab and re-open will get it working a again for ~30s.
Using this on an 4 year old computer as a reference system works perfectly well (although a bit slow)
Dell Latitude 5320
i5-1145G7 | 16GB
Intel Iris Xe Graphics
Windows 10 Enterprise 64bit (Build 18363)
Ghidel_Razvan
September 10, 2021
Hi guys!
Please check Task Manager - Performance - Memory.
For me, my Figma project eats about 8 GB of RAM. If I close all apps it works just fine, if I open chrome, slack, youtube etc. it goes dark.
So check your memory, I think this is the cause
Anton_Savellano
September 14, 2021
Super frustrated, is there no fix yet?
Beto_Lima
September 27, 2021
Hello Folks. Could you help?. My Figma app is not working in my iMac 10.15.7 (19H2)
Catalina
thanks for supporting me!
Below is the screen shot of Figma app
Captura de Tela 2021-09-27 às 16.33.02|690x440
