Create text with hyperlink
  • March 31, 2024
  • 422 views
gonzalo.vasquez
I’m creating a text from a frame/section selection. I want to convert this text to a link, or add a link property to it. My problem is that my text node doesn’t show the hyperlink property, example: textNode.hyperlink = … It says “hyperlink does not exist on type TextNode” wish is weird cause I see the property in the console.
I also check creating an HyperlinkTarget object passing it the id of my selection wich it works. But how do i pass this to a simple textNode?
Text nodes typically don’t support hyperlink properties directly. Instead, you’ll need to wrap your text node within an anchor tag (<a>) or use a specific function designed to handle links if you’re working within a particular development environment or framework.
If you’ve successfully created a HyperlinkTarget object and it recognizes the ID of your selection, you’ll likely need to apply this to an element that supports hyperlinks.
Here’s a basic example if you’re working with HTML:
<a href="your-link-target">Your Text</a>
For more specific advice, I’d need to know the exact environment or framework you’re working in. This could provide a clearer pathway to resolving your issue.
