Deniz Boomsma
Dec 7, 2025 4:34 AM UTC
Connecting Figma MCP Server with Google Antigravity
Hi all,
Is there anyone able to connect Figma MCP Server with Google Antigravity (I know it is not supported tool yet)?
I tried using client ID and secret, but I am receiving the following error:
Invalid scope: mcp:connect
Thanks a lot for comments!
aaronjellis
aaronjellisSolution
Dec 9, 2025 4:45 AM UTC
I was able to get it working via the latest Antigravity…
Just had to go into the editor, then hit these 3 dots and select MCP servers. It will ask you to install the Figma MCP config, then you should be able to run it just fine without much additional config. (easier than configuring claude code 😅).
Jan 23, 2026 1:09 PM UTC
I think it’s still not working for linux. I get this while installing figma mcp via antigravity gui:
rror: [77271] Using automatically selected callback port: 14118 [77271] Discovering OAuth server configuration... [77271] [77271] Connecting to remote server: http://127.0.0.1:3845/sse [77271] Using transport strategy: http-first [77271] Connection error: TypeError: fetch failed at node:internal/deps/undici/undici:13502:13 at process.processTicksAndRejections (node:internal/process/task_queues:105:5) at async StreamableHTTPClientTransport.send (file:///home/user/.npm/_npx/705d23756ff7dacc/node_modules/mcp-remote/dist/chunk-F76MHFRJ.js:18464:24) { [cause]: Error: connect ECONNREFUSED 127.0.0.1:3845 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1634:16) { errno: -111, code: 'ECONNREFUSED', syscall: 'connect', address: '127.0.0.1', port: 3845 } } [77271] Fatal error: TypeError: fetch failed at node:internal/deps/undici/undici:13502:13 at process.processTicksAndRejections (node:internal/process/task_queues:105:5) at async StreamableHTTPClientTransport.send (file:///home/user/.npm/_npx/705d23756ff7dacc/node_modules/mcp-remote/dist/chunk-F76MHFRJ.js:18464:24) { [cause]: Error: connect ECONNREFUSED 127.0.0.1:3845 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1634:16) { errno: -111, code: 'ECONNREFUSED', syscall: 'connect', address: '127.0.0.1', port: 3845 } } : calling "initialize": EOF.
Jan 26, 2026 8:19 AM UTC
Solution: Just install node.js https://nodejs.org/en/download/current, once installed restart your device for the path to work.
Reinstall the mcp.
 I had version 22 of the node, then updated to 25 and it's still not working. Any other tips?
OS: Ubuntu 25.10
Antigravity Version: 1.14.2
VSCode OSS Version: 1.104.0
Commit: 450b6b28083d737992adc5d19637f22c95ffba7b
Date: 2026-01-13T02:07:24.766Z (1 wk ago)
Electron: 37.3.1
Chromium: 138.0.7204.235
Node.js: 22.18.0
V8: 13.8.258.31-electron.0
OS: Linux x64 6.17.0-8-generic
Language Server CL: 855455936
Nguyễn Thanh Hưng
Jan 28, 2026 5:45 AM UTC
Reinstall the mcp.
I can’t even i use latest nodejs but issue still happen :(
cedricdsadas
Feb 13, 2026 4:28 AM UTC
Every AI is stumped by this problem. 😅
Anyone know how do I fix this?
Check if you open up your FIGMA MCP (dev mode)
Hung Nguyen
Feb 13, 2026 5:40 AM UTC
Update mcp_config.json to this works for me. I don’t use local mcp server
"mcpServers": {
"figma-dev-mode-mcp-server": {
"command": "npx",
"args": [
"mcp-remote",
"https://mcp.figma.com/mcp"
"env": {}
Dominik Golenia
Feb 25, 2026 5:46 PM UTC
Everything works. 😀 I'm an amateur at this sort of thing, so I pasted a screenshot of the problem into Google Gemini Pro. It gave me step-by-step instructions on how to run MCP and connect Figma<->Antigravity. I recommend it.
ay.mourad
Mar 1, 2026 2:48 PM UTC
this work fine with me for development tools.
Yubal Oliveras
Mar 26, 2026 5:12 PM UTC
This worked for me wonderfully, thanks!
Amanullah Menjli
May 29, 2026 6:54 PM UTC
Thank you it worked for me on linux.
camara
Jul 13, 2026 3:40 PM UTC
For me what worked was:
"mcpServers": {
"figma-developer-mcp": {
"command": "npx",
"args": [
"-y",
"figma-developer-mcp",
"--stdio"
"env": {
"FIGMA_API_KEY": "your-personal-access-token-here"
