Deniz Boomsma
Dec 7, 2025 4:34 AM UTC
Connecting Figma MCP Server with Google Antigravity
Hi all,
Is there anyone able to connect Figma MCP Server with Google Antigravity (I know it is not supported tool yet)?
I tried using client ID and secret, but I am receiving the following error:
Invalid scope: mcp:connect
Thanks a lot for comments!
aaronjellis
aaronjellisSolution
Dec 9, 2025 4:45 AM UTC
I was able to get it working via the latest Antigravity…
Just had to go into the editor, then hit these 3 dots and select MCP servers. It will ask you to install the Figma MCP config, then you should be able to run it just fine without much additional config. (easier than configuring claude code 😅).
soap
Dec 23, 2025 6:51 AM UTC
Has anyone tried connecting to a cloud MCP server?
I tried using the official config:
  "mcpServers": {
    "Figma": {
      "url": "https://mcp.figma.com/mcp"
and also switching to Antigravity’s format:
  "mcpServers": {
    "Figma": {
      "serverUrl": "https://mcp.figma.com/mcp"
Result in the error:
Error: streamable http connection failed: calling "initialize": sending "initialize": Unauthorized, sse fallback failed: missing endpoint: first event is "", want "endpoint".
Looks like I must give it access token, but where to set it?
soap
Dec 23, 2025 9:37 AM UTC
  "mcpServers": {
    "Figma": {
  "mcpServers": {
    "Figma": {
I ended up building this repo locally: https://github.com/GLips/Figma-Context-MCP.git
Using the absolute path for Node (since I'm using NVM and Antigravity couldn't find it some how...),
and clearing out the welcome messages that break the protocol.
  "mcpServers": {
    "figma-context": {
      "command": "/bin/sh",
      "args": [
        "-c",
        "FIGMA_API_KEY='your key' NODE_ENV=cli /home/{user}/.nvm/versions/node/v22.21.1/bin/node /home/{user}/ws/Figma-Context-MCP/dist/bin.js 2>/dev/null"
lison song
Dec 24, 2025 1:31 PM UTC
"mcpServers": {
"FigmaAIBridge": {
"command": "npx",
"args": [
"-y",
"figma-developer-mcp",
"--stdio"
"env": {
"FIGMA_API_KEY": "#####"
这样配置就可以了
MiaChen
Dec 26, 2025 12:05 PM UTC
I tried {
"mcpServers": {
"figma": {
"command": "npx",
"args": [
"-y",
"@modelcontextprotocol/server-figma"
"env": {
"FIGMA_PERSONAL_ACCESS_TOKEN": "XXXXX"
"figma-dev-mode-mcp-server": {
"command": "npx",
"args": [
"mcp-remote",
"http://127.0.0.1:3845/sse"
"env": {}
seems working
soap
Dec 30, 2025 7:33 AM UTC
"mcpServers": {
"FigmaAIBridge": {
"command": "npx",
"args": [
"-y",
"--stdio"
"env": {
这样配置就可以了
謝謝 這個配置比build第三方套件簡單多了
不過我還是抓不到npx所以改用sh+絕對路徑
(Alternative setup for those encountering "Error: exec: "npx": executable file not found in $PATH." errors.)
  "mcpServers": {
      "args": [
        "-c",
        "PATH=$PATH:/home/{user}/.nvm/versions/node/{version}/bin /home/{user}/.nvm/versions/node/{version}/bin/npx -y figma-developer-mcp --stdio"
      "env": {
        "FIGMA_API_KEY": "xxx"
Rainiel
Dec 30, 2025 10:27 PM UTC
Solution: Just install node.js https://nodejs.org/en/download/current, once installed restart your device for the path to work.
Reinstall the mcp.
Chayanoon Ahpaiwong
Jan 7, 2026 8:51 AM UTC
Rainiel
Jan 7, 2026 8:56 AM UTC
Reinstall the mcp.
alexey.duzhev
Jan 7, 2026 11:41 AM UTC
for remote servers it needs to know who you are.  Just add you PAT into mcp_config.json
    "figma": {
"command": "npx",
"args": [
"-y",
"figma-mcp"
"env": {
"FIGMA_API_KEY": "YOUR_PERSONAL_TOKEN"
to get token go to figma - profile - settings - security and generate new token
ARIEF BUDIMAN NASUKO
Jan 12, 2026 8:29 AM UTC
Reinstall the mcp.
Yap, it works, min using node 22+
