jonathan_Edwards
April 5, 2023
ComponentNode documentationLinks empty when it exists in inspect tab
In my plugin I get the main component from a instance, and from the main component I read the documentationLinks, but for some some reason it is empty, even though when I click on the inspect tab for the instance it has the “View documentation” button which takes you to the correct documentation.
Does this happen because the component comes from a external component library?
// prints []
console.log(instance.mainComponent?.documentationLinks)
tank666
tank666Solution
April 5, 2023
Probably, the link to the component documentation was added not to the ComponentNode, but to the ComponentSetNode. Try checking the parent of this ComponentNode.
tank666
tank666Solution
April 5, 2023
jonathan_Edwards
April 5, 2023
Thank you, that worked ☺️
