Component flows from the frame when Command D used in smart select
ecesa
Hi all!
I’m very new to Figma, so the title may not be very explanatory.
When I use smart select, I can change the order of the components and the space between them. However, when I try to duplicate one of them by using Command D, this is what happens:
It duplicates, but the frame gets slightly bigger weirdly. What could be the issue here?
Thank you!
ksn
  • 1713 replies
  • April 16, 2024
Hey @ecesa! Would you be able to share a copy of the design you mentioned in your post? I’d like to take a look to see if I can see what’s going on 😃
ecesa
  • April 16, 2024
Of course, thank you! Let me know if the link works, this is my first time sharing a Figma file 😀
https://www.figma.com/file/U1lcZttU6xxHLcsROlmg9l/fındık-coffee-!?type=design&node-id=0%3A1&mode=design&t=ABVwoGMxPHAEoeo2-1
ksn
  • 1713 replies
  • April 17, 2024
Appreciate it! It looks like I can’t access it at the moment – if you share edit access to our support email of support-share@figma.com, that should allow me to access it.
You won’t be charged or anything like that for access, and once we’ve gotten this worked out, you can revoke access.
