Morgan_Hewitt
March 31, 2021
Can't round rectangle corners
I’m not going to pretend I know what I’m talking about, but the four dots which usually appear in the inside of rectangles, so you can pull the corners simultaneously, aren’t appearing.
As it stands I can’t round the corners of my rectangles.
Any help would be appreciated!
Thanks
Screenshot 2021-03-31 at 08.50.14
    tank666
    March 31, 2021
    Morgan_Hewitt
    March 31, 2021
    I’m really sorry, but that means nothing to me!
    I’ve just started a new project board and the same thing applies. No nodes to edit the rectangle corners.
    Power Member
    March 31, 2021
    You can edit corners in the right panel. It looks like the zoom level might be too little for corner controls to show. If you zoom in more and this is a real rectangle and not a simple vector, you will see corner markers too.
    ata_kan
    Hi @Morgan_Hewitt
    I am a starter and faced same problem.
    Thanks for your question above.
    I noticed that if you double click on corner marks, it switches between 2 mode.
    2 modes : With corner circle mark (editable corner angle) and without circle mark (only editable at side panel).
