David_Goligorsky
Can't override position of absolute positioned element within a component instance
  • January 26, 2023
  • 1800 views
I’ve got a component that has an absolutely positioned item.
When I make an instance of the component, I’m not able to change the position of the absolutely positioned item. 🥲
Couldn’t seem to find a solution in the forum or Google.
Is this a bug? A feature 😂?
I know I can detach the instance to move the position, but I need to keep this as a component instance.
Thanks in advance! 🤗
Best answer by tank666
You can’t move objects in instances, you have to do it in the main component.
tank666
tank666Answer
January 26, 2023
